Degree level vector help required.
  • Thread starter Thread starter Brains_Tom
    Degree Vector
The discussion revolves around the application of vector products in various contexts, including determining orthogonality of vectors, calculating the area of a triangle using given coordinates, and finding the shortest distance between two lines in three-dimensional space.
  • Participants explore how the vector product can demonstrate orthogonality between two vectors and question the relationship between the sine of the angle and the resulting vector. There are inquiries about how to express the area of a triangle using vector products and the implications of given coordinates. Additionally, discussions arise regarding the shortest distance between two lines and the necessary conditions for the calculations.
Some participants have provided insights into the properties of the vector product and its applications, while others express confusion about specific calculations and concepts. There is an ongoing exploration of the relationships between the vectors and the geometric interpretations of the problems presented.
Participants are working within the constraints of homework guidelines, which may limit the depth of assistance provided. There is a recognition of potential misunderstandings regarding vector properties and calculations, particularly in relation to orthogonality and area determination.
Brains_Tom
Hi folks first post, i am a 20yr old student from north-west england, hope you guys can help me and i can return the favour some time.
1) How can the vector product be used to show two vectors are orthogonal to each other?
a=2i-5j+3k
b=-i+j+k
2)How can the vector product be used to show an expression for the area of a triangle using the below co-ordinates?
(2,0,1) (3,1,7) (-2,5,5)
3)Using two lines...
L1: r=p+λn L2: s=q+µm
where...
p=8i+9j+3k
n=i+j
q=-2i-4j+k
m=i+2j
...and a suitable minimum distance formula, find the shortest distance between the two lines, providing a straight line indicates this distance, find the position vectors of these two connecting points, one on each line.
Many thanks.
I know what the vector product is mate i just don't know how to answer the question, as for 2, can you clarify, how do i put this into three dimensions for an actual result?
Well if 2 vectors are othogonal, you'll get [tex]\sin \theta=1[/tex]. Then you just show that [tex]|u \times v| = |u||v|[/tex], which just involves you sitting there and working it out manually.
For the second question, you're given the position of the triangles vertices, so you can derive vector expressions for the sides. Then, you can see from the link I posted that the area of a triangle is the half the product of 2 sides times sin of the angle between them. Sound familiar, its
[tex]\frac{1}{2}|u||v|\sin \theta[/tex] which is otherwise written [tex]\frac{1}{2}|u \times v|[/tex]. Hence, work out the vector expressions for two of the triangles sides and then halve the mod of their cross product for the area.
For the third one you're looking for a plane which one line lies in and which is normal from the second one.
1) But i get mod(a) x mod(b) = sqrt(114) and mod(axb) = sqrt(38) ?
If you look closely you'll see that they aren't actually orthogonal to each other. Try calculating the dot product for example. If that -1 in front of the i on b was a 1, then the vectors would be orthogonal.
SORRY - EDIT
a=2i-5j+3k
b=-i+j+k
where...
p=8i+9j+3k
n=i+j
q=-2i-4j+k
m=i+2j
Many thanks.
1) Use the vector product to find two unit vectors that are orthogonal to both 'a' and 'b'? a=2i-5j+3k b=-i+j+k
Find the area by evaluating this vector product expression.
Well annoying, sorry.
Ok, the question makes a good deal more sense now. The basic fact to use is that the vector product produces a vector which is orthogonal to both the inputs.
But what do i use for the angle, do i presume sin(theta) is just one, then just multiply the magnitudes, surely that would just give a numeric answer, when i am after a vector, i do understand that my two answers will be the same vector just opposite sign though.
  • · Replies 16 ·
  • · Replies 19 ·
9K
