Derivation of Kutta Joukowski condition
- Level: Graduate
- Thread starter DrDu
- Start date
- Tags
- Condition Derivation
4 replies · 4K views
Discussion
- 24,488
- 15,063
Have a look at Wikipedia as a first introduction to the subject:
http://en.wikipedia.org/wiki/Kutta–Joukowski_theorem
- 3,482
- 1,293
A good book that goes into the math and theory of ideal flows (e.g. Kutta-Joukowski) would be "Principles of Ideal Flow Gas Dynamics" by Karamcheti.
- 1,006
vanhees71 said:Have a look at Wikipedia as a first introduction to the subject:
Thank you, but I meant the Kutta condition, not the theorem.
- 1,006
More specifically: I was reading on how physically correct solutions to the frictionless Burgers equation are constructed when a shock appears as "weak solutions" of the general equation in the limit of vanishing viscosity. Entropy is then only generated at the shocks and searching for a solution which minimizes entropy production leads to the correct result. In easy two dimensional air foil problems one only has to fix the value of rotational flow. I wonder whether this can not also be reduced to a problem of minimizing entropy.
In the inviscid flow the velocity becomes infinite at a sharp trailing edge for almost all values of the rotation. If a small viscosity is introduced, velocity is no longer infinite but there would probably a lot of entropy be generated.
Graduate Does Kutta Joukowski Theorem applies to Coanda effect (UAV)?
- godilocks9999
- · Replies 5 ·
- Mechanics
- Replies
- 5
Graduate Fourth order Runge Kutta derivation equation C.54
- ATY
- · Replies 10 ·
- Differential Equations
- Replies
- 10
Joukowski transformation pressure coefficient discontinuity on cambered airfoil
- danja
- · Replies 4 ·
- Mechanical Engineering
- Replies
- 4
Graduate Understanding coupled Runga Kutta derivation
- ognik
- · Replies 17 ·
- Replies
- 17
