ecastro
- 249
- 8
I got stuck in deriving the velocity of the particle from the acceleration equation. Here are the details of the problem.
The acceleration of a particle with a relativistic momentum is
\vec{a} = \frac{\vec{F}}{\gamma m} - \frac{\vec{v}}{\gamma m c^2}\left(\vec{F} \cdot \vec{v}\right).
By integrating the above equation, the velocity of the particle can be calculated if the force applied and the mass of the particle are given. The greek letter \gamma in this case is \left(1 - \frac{v^2}{c^2}\right)^{-1/2}
Considering that a constant force \it{F} is applied to a mass \it{m} initially at rest, the velocity of the particle is
\int \vec{a} dt = \int \left[\frac{\vec{F}}{\gamma m} - \frac{\vec{v}}{\gamma m c^2}\left(\vec{F} \cdot \vec{v}\right)\right] dt \\<br /> <br /> \vec{v} = \int \left[\frac{\vec{F}}{\gamma m} - \frac{\vec{v^2}}{\gamma m c^2}\left(\vec{F} \right)\right] dt.
Since F and m are constants in time, they are removed from the integral. Gamma is taken out from the two terms. Then,
\vec{v} = \frac{\vec{F}}{m} \int \frac{1}{\gamma} \left(1 - \frac{v^2}{c^2}\right) dt.
Using the definition of gamma, the integrand is
\vec{v} = \frac{\vec{F}}{m} \int \left(1 - \frac{v^2}{c^2}\right)^{3/2} dt.
This is where I get stuck. I don't know how to integrate it since the integrand is not a direct function of t but of v which is a function of t. I tried having v = at, but I don't know if this is correct.
