Derivative of Newton's Law of Gravitation
The discussion revolves around the derivative of Newton's Law of Gravitation, specifically focusing on the expression for gravitational force and its rate of change with respect to distance. Participants explore the implications of the derivative, particularly the significance of the negative sign in the context of attraction between masses.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the differentiation of the gravitational force equation, with some expressing confusion over treating masses as constants during differentiation. Others attempt to clarify the reasoning behind this approach and the implications of the derivative's negative sign.
The conversation is progressing with participants sharing insights and clarifications about the differentiation process. Some have provided guidance on the treatment of constants in the context of the derivative, while others are seeking deeper conceptual understanding.
There is an ongoing exploration of the assumptions regarding the variables involved in the gravitational force equation, particularly the independence of mass variables from the distance variable during differentiation.
Bear_B
Newton's Law of Gravitation says that the magnitude (F) of the force exerted by a body of mass (m) on a body of mass (M) is
F = (GmM)/(r^2)
where G is the gravitational constant and r is the distance between the bodies.
Find dF/dr and explain it's meaning. What does the minus sign indicate?
none
using implicit differentiation:
dF/dr = d/dr [(GmM)/r^2]
= [(r^2)d/dr(GmM) - (GmM)d/dr(r^2)] / (r^4)
= [(r^2)G(d/dr(mM)) - (2rGmM)] / (r^4)
= [(r^2)G(m * dM/dr + M * dm/dr) - 2rGmM] / (r^4)
Ok, I know this can be simplified, but that seemed even more convoluted when I did that. I'm really not sure what to do from here. I expected the derivative to be something a little more intuitive and to result in a negative expression based on the question. I would expect dF/dr to equal a negative expression and the significance of the minus sign to be indicative of a force of attraction since the derivative is with respect to distance and the distance is decreasing. Please help me with the derivative, because If I can get that right, then I just need to express what's going on in words.
Hi Bear_B! :wink:
(try using the X2 tag just above the Reply box :wink:)
F = (GmM)/(r^2)
ooh, so complicated! :cry: no, m and M are constants.
Try again. :smile:
Ok, I had seen that result worked out elsewhere when I couldn't get on here. Can you please tell me why m and M are constants? I thought the equation to determine the gravitational force was for an unknown mass m and an unknown mass M at a unknown distance r from each other...knowing that m and M are constants makes the differentiation simple, I just want to understand why I am treating m and M as constants. Thanks
F = GmM/r2
dF/dr = GmM [ d/dr (r-2)]
= GmM (-2r-3)
= GmM (-2/r3)
dF/dr = -2GmM / r3
ok, so here is the answer, but why are m and M constants?
Because they have nothing to do with r. They are masses.
Hi Bear_B! :smile:
(just got up :zzz: …)
Yes, m and M are variables just like r,
but they are independent variables (they can be varied separately, without affecting the others).
So when the question asks "Find dF/dr", it means differentiate with respect to r, keeping all other variables constant. :smile:
Thanks. Now I understand the concept that the Force (F) is being taken with respect to distance (r) determining the rate of change of F as r changes for two objects with mass m and M. Since dF/dr is asking how F changes when r changes it has to assume that the m and M are constants unless otherwise indicated. I think I get it now. I just wanted a conceptual understanding of the problem beyond how to do the problem mechanically (because that is the easy part).
^^ This is my (basic) understanding of why the derivative assumes m and M as constants when differentiating with respect to r.
  • · Replies 16 ·
