Derivatives in spherical coordinates
In quantum mechanics, the momentum operator in spherical coordinates transforms into a form involving the radial part of the Laplacian, specifically represented as a second derivative. The discussion highlights the importance of using the chain rule for partial derivatives when converting between coordinate systems. The Hamiltonian is expressed in terms of radial momentum, but there is confusion regarding the correct representation of the momentum squared operator. The correct form includes a factor of 1/r due to the curvature of spherical coordinates, contrasting with Cartesian coordinates. The conversation emphasizes the complexity of these transformations and the utility of differential geometry for deeper understanding.
maria clara
In quantum mechanics the momentum operator is a constant multiplied by the partial derivative d/dx. In spherical coordinates it's turning into something like that:
constant*(1/r)(d^2/dr^2)r
can anyone explain please how this result is obtained?
That doesn't look like d/dx, it looks like the radial part of the laplacian. It's a second derivative. In general to convert derivatives between coordinate systems you use the chain rule for partial derivatives.
the momentum operator is often written as -ihd/dx... but in that case x is the position vector. More generally, the momentum op is -ihDel (Del = the gradient operator, more easily generalized to different coordinate systems). (note also that i have written 'h' but mean "h-bar").
As dick said, the operator you've shown doesn't look quite right... if something is only changing radially, then the grad in spherical is just d/dr (i believe).
sorry, my mistake.
I meant the radial part of the (momentum)^2 in spherical coordinates.
If the Hamiltonian is:
(Pr)^2/2m + L^2/2mr^2 +V(r)
what's wrong in writing (Pr)^2 as
-(hbar)^2*(d/dr)^2
why is it written like that:
(-(hbar)^2/r)*(d/dr)^2*r
Because the grad^2 operator is only the sum of coordinate derivatives squared in cartesian coordinates. Spherical coordinates are curved. Here's a derivation.
http://planetmath.org/encyclopedia/%3Chttp://planetmath.org/?method=l2h&from=collab&id=76&op=getobj
BTW there are much better ways to derive this using differential geometry, but it gives you an idea of WHY the answer isn't as simple as you think. No need to follow all of the details.
wow... I'll take a look at that, thanks!
Just want to thank you, this website is basically my homework assignment this week. I have been getting my *** worked until i found this.
THANK YOU
