Derivatives of Trig with Triangles
The discussion focuses on finding the rate at which the area of a triangle is decreasing when the angle between two fixed sides is pi/6 radians. The given sides are six and eight meters, and the angle is decreasing at a rate of 0.035 rad/s, leading to a calculated area decrease of 0.727 m²/min. Participants debated the use of Heron's formula, concluding it was not suitable due to the lack of knowledge about all three sides. Instead, expressing the area as a function of the two sides and the angle was recommended for easier differentiation. The conversation clarified the application of constants in differentiation, emphasizing the importance of understanding the derivative process.
LadiesMan
[SOLVED] Derivatives of Trig with Triangles
1. Two sides of a triangle are six and eight metres in length. If the angle between them decreases at the rate of 0.035 rad/s, find the rate at which the area is decreasing when the angle between the sides of fixed length is pi/6. Answer 0.727 m^2/min
2. I tried using Heron's formula but I realized it was almost impossible to take the derivative somehoe with the angle needed. My givens are
dtheta/dt = -0.035 rad/s
the angle between them is pi/6 or 30 degrees
Now to find da/dt...
Thanks
I'm not sure why you're using Heron's formula - that looks to be better when you know all three sides and don't necessarily know any of the angles.
Can you express the area as a function of the two fixed lengths and the contained angle? It's pretty simple to take the derivative of the relevant expression.
no sry i don't understand how to express the equation but what i think is cut the triangle into two?
nvmi got it thank you very much! =) But one thing when u take the derivative of 24sin theta,w hy is it that u leave the 24?
I'm not sure I understand your question. It's just:
d/dt (k*f(t)) = k* df/dt , k = constant
Is that clear?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
