Derive the density of an ideal gas as a function of temperature?
The density of an ideal gas can be derived using the equation density = PM/(RT), where P is pressure, M is the molecular weight, R is the ideal gas constant, and T is temperature. When pressure is kept constant, the relationship between density and temperature can be expressed as ∂ρ/∂T = M/(RT). This indicates that the density of the gas is directly proportional to its molecular weight and inversely proportional to temperature, regardless of whether the gas is expanding or compressing.
  • Understanding of the Ideal Gas Law
  • Familiarity with the concepts of pressure, volume, and temperature
  • Knowledge of molecular weight and its significance in gas equations
  • Basic calculus for understanding derivatives
  • Study the Ideal Gas Law and its applications in thermodynamics
  • Learn about the implications of constant pressure on gas behavior
  • Explore the relationship between density and temperature in real gases
  • Investigate the derivation of other gas properties using the Ideal Gas Law
Students studying thermodynamics, physicists, and chemists interested in the behavior of gases under varying temperature and pressure conditions.
Outrageous
derive the density of an ideal gas as a function of temperature??
Derive the density of an ideal gas when it is allowed to expand as a function of temperature when pressure is kept constant/
density= PM/(RT) , where M is the molecular weight
or ∂ρ/∂T =M/(RT)
or ρ(V,P),then keep P constant, ∂ρ/∂V =∂<PM/(RT)>
actually i am not sure what the question asking about . Thank you
or ∂ρ/∂T =M/(RT)
Relate the mass of the gas to the volume using the ideal gas equation. Use n = m/M where m is the mass of the gas and M is the molecular weight or mass/mole of the gas.
What is n/V? How is n/V related to density of the gas?
AM
m/V is density of gas system
n /V is density of gas molecule?
I don't know how to relate.
... and since m = nM... the density of the gas is ... (in terms of M, P, R and T).
AM
or ∂ρ/∂T =M/(RT)
So the question want density in terms of P M R T? Then why does the question say when it expand?
You should ask the person who drafted the question...it was probably asked this way to just give it some context. What the question is asking is the relationship between T and m/V with constant P. Whether it is expanding or being compressed at constant P makes no difference to the relationship.
AM
AM
Thank you.
  • · Replies 33 ·
  • · Replies 19 ·
  • · Replies 17 ·
