Deriving Snell's Law
  • Context: High School
  • Thread starter Thread starter WheatNeat
    Snell's law
This discussion focuses on the derivation of Snell's Law, specifically addressing the use of perpendiculars to compare two paths and the implications of angle approximations. It is established that the error associated with using perpendiculars is of higher order than first order, making this approximation valid. The angles ε and φ are discussed, with φ being shown to differ from θ₂ to first order as X approaches C, while maintaining accuracy in the distance XF through zeroth order approximation.
  • Understanding of Snell's Law and its derivation
  • Familiarity with basic trigonometry, particularly isosceles triangles
  • Knowledge of first-order and higher-order approximations in calculus
  • Concept of angle approximation in geometric contexts
  • Study the derivation of Snell's Law in detail using geometric optics
  • Explore first-order and higher-order approximations in calculus
  • Learn about the properties of isosceles triangles in optics
  • Investigate the implications of angle approximations in physical models
Students of physics, particularly those studying optics, mathematicians interested in geometric approximations, and educators teaching Snell's Law derivations.
WheatNeat
TL;DR
Why are perpendiculars used to compare the two paths, and where does this angle approximation come from?
Here we are deriving snell's law. The text compares the length of the two paths (which are assumed to be close enough such that the time difference is negligible), and uses the perpendicular to compare them. They should technically be making an isoceles triangle to compare them right? Is this an approximation? Also the text says that angle FCX is approximately equal to angle BCN', but this doesn't seem to be true in the limit as X approaches C. What am I missing?
Science news on Phys.org
WheatNeat said:
TL;DR Summary: Why are perpendiculars used to compare the two paths, and where does this angle approximation come from?
Yes, that's right. You can show that the error associated with this approximation is of order higher than first order. So, it's ok.
Label the angles as shown.
The angle ε is small of first order when distance XC is small compared to distance CB.
Show that ##\phi = \theta_2 + \varepsilon##. So, as X approaches C, ##\phi## differs from ##\theta_2## to first order. However, you are interested in the distance ##XF##, which equals ##XC \sin \phi##. Since ##XC## is already a small, first order quantity, ##XC\sin \phi## will be accurate to first order if you use the "zeroth order" approximation ##\phi \approx \theta_2##.
  • · Replies 20 ·
  • · Replies 35 ·
  • · Replies 20 ·
