Deriving tan power series
In summary, the tan power series can be derived from the sin and cos power series by taking the odd and even terms respectively. However, this method does not directly show how Bernoulli numbers are involved, but it does provide an explicit formula for them.
Piano man
75
How can the tan power series be derived from the sin and cos power series?
Where do the Bernoulli numbers come in?
Mathematics news on Phys.org
It's generally not done from the sine and cosine series:
http://www.mathhelpforum.com/math-help/f25/power-series-tangent-function-108861.html
I was expecting something yucky, and this doesn't disappoint...
Thanks for the link :)
Piano man. Here is a link in http://www.voofie.com/concept/Mathematics/" that you maybe interested.
http://www.voofie.com/content/117/an-explicit-formula-for-the-euler-zigzag-numbers-updown-numbers-from-power-series/"
I derived the power series of the function sec x + tan x. For the tan x power series, you just take the odd terms from the expansion, since tan x is an odd function. While sec x corresponds to the even terms from the power series, as sec x is even.
It doesn't really show how Bernoulli numbers enter the expression, but it derives an explicit form for Bernoulli numbers.
The tan power series can be derived from the sin and cos power series by using the identity tan(x) = sin(x)/cos(x). This allows us to rewrite the tan function in terms of the sin and cos functions. By substituting this identity into the power series expansions of sin(x) and cos(x), we can manipulate the terms to obtain the power series for tan(x). This is a useful technique for expanding the tan function into a series of terms that can be more easily manipulated and approximated.
The Bernoulli numbers come into play when we expand the power series for cos(x) using the Maclaurin series formula, which involves the Bernoulli numbers. This is because the coefficients in the power series for cos(x) are related to the Bernoulli numbers through a specific formula. In this way, the Bernoulli numbers are indirectly involved in the derivation of the tan power series.
Moreover, the Bernoulli numbers also appear in the coefficients of the power series for tan(x) itself. This is because the power series for tan(x) involves only odd powers of x, and the Bernoulli numbers are involved in the coefficients of these odd powers. Therefore, the Bernoulli numbers play a crucial role in the derivation of the tan power series and are intimately linked to the coefficients of the series.
What is a power series?
A power series is an infinite polynomial expression that can be used to approximate a function. It is written in the form of ∑n=0∞ an (x-c)n, where an represents the coefficients and c is the center of the series.
Why is it important to derive the tan power series?
Deriving the tan power series allows us to express the tangent function as a polynomial series, which makes it easier to approximate and calculate the values of the tangent function at different points. This is especially useful in fields such as physics and engineering.
How do you derive the tan power series?
To derive the tan power series, we use the Maclaurin series expansion for the tangent function, which is tan(x) = x + (1/3)x3 + (2/15)x5 + (17/315)x7 + ... . We can then use this equation to find a general formula for the coefficients, which can be used to express the tangent function as a power series.
What is the purpose of using a power series to approximate a function?
Using a power series to approximate a function allows us to break down a complex function into simpler terms, making it easier to calculate the function at different points. It also provides a more accurate approximation than using a finite number of terms, as we can always add more terms to improve the accuracy.
Can the tan power series be used to find the values of the tangent function at any point?
No, the tan power series is only a representation of the tangent function and cannot be used to find the values of the tangent function at any point. It can only provide an approximation of the function, and its accuracy depends on the number of terms used in the series.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
