Deriving the Schwarzschild metric just by using the equivalence principle
The discussion revolves around the derivation of the Schwarzschild metric using the equivalence principle, exploring the validity of relating non-inertial and inertial frames through Lorentz transformations. Participants examine the implications of using these transformations in the context of constant-linear-acceleration frames and the broader applicability of the equivalence principle across different metric theories.
  • One participant questions whether Lorentz transformations can be applied to relate non-inertial frames to inertial frames, given that the derivation of such transformations typically assumes inertial conditions.
  • Another participant expresses skepticism about the feasibility of the derivation, noting that many metrics and theories align with some form of the equivalence principle, but does not provide a definitive answer.
  • There is a repeated inquiry into the applicability of Lorentz transformations in constant-linear-acceleration frames, with some participants suggesting that they may only apply locally.
  • A participant mentions that the author of a referenced paper does not use Lorentz transformations but instead applies time dilation and length contraction, which they argue is incorrect.
  • Another participant references Taylor & Wheeler's textbook, discussing the "rain frame" metric and its implications for local flatness in the context of falling objects near a black hole, suggesting that Lorentz transformations can be valid in certain contexts.
  • Additional references to other works that combine Lorentz transformations with the Schwarzschild metric are provided, indicating that such applications may be conceptually sound if approached carefully.
Participants express differing views on the applicability of Lorentz transformations in non-inertial frames, with no consensus reached on whether these transformations can be used in the context of constant-linear-acceleration frames. The discussion remains unresolved regarding the validity of the derivation methods discussed.
Participants highlight limitations in the assumptions made regarding the frames of reference and the conditions under which Lorentz transformations are applied. The discussion also touches on the varying interpretations of the equivalence principle across different metric theories.
Huashan
I've read a few papers about derivation of the Schwarzschild metric by using the equivalence principle ( http://cdsweb.cern.ch/record/1000100/files/0611104.pdf" )... but I couldn't understand them completely
they assume , According to Einstein’s equivalence principle, that the influence of gravitation on phenomena in a local reference frame that is at rest in the field is equivalent to the influence of the accelerated motion of a local reference frame in which phenomena are described in the absence of gravitation . ( till now there is no problem ).
and then for such an accelerated frame they write the metric in the form :
(no problem yet ).
then... they relate the local coordinates x’, t’ in the accelerated frame to the corresponding coordinates in the stationary frame by the usual differential form of the Lorentz transformation for the value of the velocity that has been reached , by the formulae :
here is the problem ... can these frames be related to each other by the above expressions ?? According to the fact that one of them is non-inertial frame? ... the derivation of the above expressions are based on the fact that the frames are inertial and moving with respect to each other with a constant velocity v .
Can anybody help me?? ...
I don't think it can be done, since many metrics (and many theories, not just general relativity) are consistent with some sort of equivalence principle.
yes I know ... my question is whether we can use Lorentz transformations (in the same form as they are locally in SR ) in constant-linear-acceleration frames or nor ?, if yes how ?...
Along atyy's comments, I've heard that Nordstrom's theory of gravity satisfies the strong equivalence princple. I searched and found a paper that made this claim in passing, but couldn't find any that had a good discussion on this. Can anyone comment if this is true about Nordstrom's theory?
This sounds a bit over-stating the case, but wikipedia claims:
"All metric theories satisfy the Einstein equivalence principle"
http://en.wikipedia.org/wiki/Brans-Dicke_theory
Is that really true? Then is the only issue whether a metric theory satisfies the strong equivalence princple?
You can always locally make the metric match that of flat spacetime. And then yes, the lorentz transformations apply locally at least. I think it is valid only in that sense.
Maybe one should mention that the author does not use Lorentz transformations, but timae dilation and length contraction applied to basic vectors, which is wrong.
Lorentz transformations leave all intervals (the metric) unchanged. That's more or less how they are defined.
This paper is cranky, not surprising as the author is a philosopher.
Huashan, a reliable source you may want to look at for additional perspective on this is Taylor & Wheeler's excellent textbook "Black Holes." In Query 3 on p B-7 and on p B-13 they combine a Lorentz transformation with the Schwarzschild metric to create a metric for an object in radial freefall from infinity toward a black hole, which they refer to as the "rain frame."
This metric demonstrates that in the frame of the falling object, the local space is flat regardless of the spacetime curvature. They credit this metric to Charles Misner, who in turn derived it from Painleve & Gullstrand.
The Painleve-Gullstrand metric for the "river model" described in the Czerniawski paper you cite certainly is a widely accepted and quite interesting variation on the Schwarzschild metric.
Taylor & Wheeler reference a paper providing formal derivations and references:http://arxiv.org/abs/gr-qc/0001069" by Martel and Poisson, AJP 69-4, 2001, p. 476-480.
Peacock also combines a relativistic Doppler shift and a gravitational shift to derive a formula for the cosmological redshift in Schwarzschild coordinates, in his http://arxiv.org/abs/0809.4573" , eq. 16. This equation produces demonstrably correct calculations.
There probably are many other reliable examples to be found where equations using Lorentz transformations are applied in the context of the Schwarzschild metric. Conceptually I see nothing wrong with doing so, as long as one is careful.
  • · Replies 44 ·
  • · Replies 0 ·
  • · Replies 19 ·
