Design experiment to determine bending strength and torsion of ruler
This discussion focuses on designing experiments to measure the bending strength and torsion of a plastic ruler using limited tools. The proposed methods include applying force at the ruler's end and measuring the angle of bend with a protractor, as well as applying force at the center while supported at both ends. The importance of understanding stiffness versus strength is highlighted, emphasizing that measuring deflection under load provides insights into stiffness rather than ultimate strength. The use of a dynamometer is suggested for force measurement, although the lack of precise measuring devices limits the accuracy of the experiments.
  • Basic understanding of material mechanics
  • Familiarity with force measurement using a dynamometer
  • Knowledge of angle measurement with a protractor
  • Concept of stiffness versus strength in materials
  • Research methods for measuring deflection in materials under load
  • Learn about the properties of plastic materials and their stress-strain behavior
  • Explore experimental designs for torsion testing of materials
  • Investigate the use of more precise measuring devices for material testing
Students in materials science, engineers conducting material testing, and hobbyists interested in simple mechanical experiments.
patehi
hello everyone!
so as the title suggest, i wonder if anyone would have any idea to design a simple experiment to determine the bending strength and torsion of a plastic ruler.
it doesn't need to be extensive, as the value of the strenght itself isn't important. i just want to know e.g how far could the ruler bend before breaking. and when i have the result, i could compare it with another plastic ruler.
I don't have any measuring devide, all i have is a protractor and ill have some way of determining the angle of bend.
(i also have a dynamometer if that would help in any way)
here is my suggestion of the bending strength experiment:
http://imageshack.us/a/img199/3729/vj0e.png
for this experiment i just put the ruler on the table and apply F at the end and determine the angle. Although it is actually pretty inaccurate to read the angle to determine its strengh :/
and here another suggestion:
http://imageshack.us/photo/my-images/9/rjkx.jpg/
i put the ruler on 2 objets and apply F to the middle part.ill determine how far will it bend in cm.
Do you guys have any suggestion for this experiment? as i said, i have limited device and i would prefer an experiment as simple as possible.
Also, i would be needing a design experiment to determine the torsion of the plastic ruler too. Alhthough i don't really know how to do it without proper measuring divide :/
So i would appreciate if anyone could give an idea about it! Thank you!
I am not sure what you are trying to accomplish. If you are placing a force on the ruler less than that required to break it, and determining its deflection or rotation angle under that force, you will determine how stiff the ruler is and not how strong it is. For example, certain grades of aluminum have the same strength of certain grades of steel, but the aluminum of the same dimensions as the steel will deflect three times more under the same load. Or you can take a low strength steel and a high strength steel and discover they will have the same deflection under the same load up to the yielding failure of the former.
  • · Replies 24 ·
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 21 ·
