Design Logic Question: 3 Inputs, 3 Outputs | 2 Inverters
  • Thread starter Thread starter mnm
    Design Logic
The discussion revolves around designing a digital circuit with three inputs (a, b, c) and three outputs (a', b', c') using only two inverters and any number of AND and OR gates. Participants clarify that the outputs represent the inverted values of the inputs, and the challenge lies in achieving three independent outputs without isolating each variable with a NOT gate. The solution involves applying logical equivalences and DeMorgan's law to construct the necessary expressions for the outputs.
  • Understanding of digital logic design principles
  • Familiarity with DeMorgan's theorem
  • Knowledge of combinatorial logic circuits
  • Experience with Boolean algebra
  • Study the application of DeMorgan's theorem in circuit design
  • Learn about combinatorial logic circuit optimization techniques
  • Explore advanced Boolean algebra techniques for circuit simplification
  • Investigate the use of Karnaugh maps for minimizing logic functions
Electrical engineers, digital circuit designers, and students studying logic design who are looking to enhance their understanding of combinatorial circuits and Boolean logic applications.
mnm
Helloo every one,
here is my qusetion:
Design acircuit that has three inputs a,b,c and has three outputs a' ,b', c' . your circuit can only have two inverters and any number of AND and OR gates
if some 1 could help me i'd appreciate it.
I think this is a:devil: bounes quetion ,so u should solve :smile:it alone mnm.
?? It's not clear to me, or to anyone else I suppose, under what conditions would the outputs be asserted. In other words, what is this circuit supposed to do?
well u have 3 inputs a b and c and a circuit that consists of only 2 not gates and any number of AND and OR gates u must now construct those gates inorder to get 3 out puts separetly which are a' b' and c'
that is the question and a hint would be is that it is necessary to use more than 20 gates.
You're not answering the question of what the circuit does. I could easily designate a',b',c' outputs the same as the inputs and use the two inverters in series to cancel each other out. Would you mind posting the problem as it is?
EDIT: Someone pointed out to me that a',b',c' refer to the inverted outputs of a,b,c. Now I understand the question.
please post the complete question... mean what is the equation??
it is a+b+c (just for example) or what??
f(A,B,C) = A', B', C'
The difficulty is in getting three independent outputs when he can't just isolate each variable with a NOT gate.
Hint: There are logical equivalences you can make use of to filter your combinatorial (And/Or) outputs. Brush up on your logic rules. Make some attempts at a solution, so people can help you further.
I was bored so I made a rough outline for you to get started. I've uploaded and linked the picture, but since I renamed all your symbols in greek you will probably have to start from the beginning to use the picture i provided.
This problem is an excellent example of pretty difficult "easy" problems. Your professor (and other smarty pantses who have solved this) will promote it as a "novel" example, and it is, but this ignores the fact that the solution is quite involved. Indeed, anyone can solve this problem using very simple rules, but coming to the solution on your own requires some concerted effort.
The easiest place to start is to consider what the solution will look like. Take your initial variables, XYZ, and you need to end up with their complements: X', Y', Z'. Using DeMorgan's law, how can you obtain X (or it's complement) from a sum (OR) of other expressions? Write an expression for a single variable first:
X = (X+Y+Z)'(X+Y+Z')'(X+Y'+Z)'(X+Y'+Z')'
X' = X'Y'Z' + X'Y'Z + X'YZ' + X'YZ.
From this, you should be able to see that you need to construct (using your 2 given NOT gates) 2 types of expressions: one containing terms with 2 NOT'ed variables, and one containing terms with 1 NOT'ed variable. Try to build these, or at least work backwards from the awful drawing I made, and you should be able to see how the solution works. You will see that these will necessarily involve terms including all three, starting from basically X'Y'Z' and (X' + Y' + Z').
http://i289.photobucket.com/albums/ll222/snarfherder/solution.jpg
Smiley faces are OR gates. Good Luck.
