Detailed modeling of a Pulley System, HELP
The discussion focuses on the detailed modeling of a pulley system, emphasizing the need to account for the stretchability of the wire rope, damping effects, and friction between the sheaves and bearings. The user is working on equations for the angular position, velocity, and acceleration of each sheave, as well as the tension in the wire segments affected by friction. There is uncertainty about how to model the velocities of the sheaves, particularly regarding whether they can be different due to the stretchable nature of the wire. The user seeks clarity on how to accurately represent the dynamics of the system, including the moments on the sheaves and forces acting on the weight. The complexity of the modeling process is acknowledged, indicating a need for further assistance.
gtavictor
Detailed modeling of a Pulley System, HELP!
Hello people,
Currently I have a project of a pulley system, and I have to model it with fair detailed equations. Actually this continues from another thread I started sometime ago, but I made a new thread because now I'm continuing with the project. The next are the considerations I need to be aware of:
  • Wire rope as a stretchable string (I suppose I have to model it as a spring).
  • Damping in the wire can be neglected but consider a very high stifness of the wire so small permanent oscillations occur in the system.
  • Angular position, velocity and acceleration of each sheave.
  • Displacement, velocity and position of the sheaves attached to the weight, in this case is obvious both sheaves and the weight share the same translational movements.
  • Consider \mu as the friction between shaft and bearing of the sheave.
  • Consider the friction between wire rope and sheave high enough so no sliding occurs.
Sheave modeling: For this I'm based on the first and second images. I'm doing the modeling for the velocities, so if I integrate or derivate I get position or acceleration respectively:
Sheave1: in this case v_{c1}=0
v_{a1}=v_{c1}-R*\omega_1=-R*\omega_1
v_{b1}=v_{c1}+R*\omega_1=R*\omega_1
v_{a1}=-v_{b1}
Sheave2:
v_{a2}=v_{c2}-R*\omega_2
v_{b2}=v_{c2}+R*\omega_2
Sheave3: in this case v_{c3}=0
v_{a3}=v_{c3}-R*\omega_3=-R*\omega_3
v_{b3}=v_{c3}+R*\omega_3=R*\omega_3
Sheave4: in this case v_{b4}=0
v_{a4}=v_{c4}-R*\omega_4
v_{b4}=v_{c4}+R*\omega_4 --> v_{c4}=-R*\omega_4
also --> v_{a4}=-2*R*\omega_4
Then I consider the velocities the same where I have one same string connected:
v_{b1}=v_{a2}
v_{b2}=v_{a3}
v_{a4}=v_{b3}
From this sheaves modeling I don't know if these velocities I mentioned before are the same, from the initial considerations I have a stretchable spring but from what I know the velocities in both ends of the wire segment between sheave and sheave should not be the same, if that's the case then, how can I model each sheave individually with different velocities?
Tensions in each wire segment due to friction shaft-bearing: For this I'm based on the first image, starting for the rightest sheave (where less tension should be applied in the wires due to the final fixed point).
r=Radius of shaft
R=Radius of sheave
For sheave 4:
N=T_2+T_1
\mu*N*r=(T_2-T_1)
N=\frac{(T_2-T_1)*R}{\mu*r}
\frac{(T_2-T_1)*R}{\mu*r}-T_1-T_2=0
T_2=\frac{T_1*(R+\mu*r)}{R-\mu*r}
then for sheave 3:
T_4=\frac{T_1*(R+\mu*r)^2}{(R-\mu*r)^2}
then for sheave 2:
T_6=\frac{T_1*(R+\mu*r)^3}{(R-\mu*r)^3}
then for sheave 1:
F_w=\frac{T_1*(R+\mu*r)^4}{(R-\mu*r)^4}
For this modeling I just did I see from the equations that I have an increase of tension due to the friction between shaft and bearing of the sheave, but like for the previous modeling I'm not sure if I'm doing good, also, the tension in 1 should be IDEALLY:
T_1=\frac{W}{MA} where MA is the mechanical advantage equal to 4 for this pulley system, but still this is IDEALLY, so I don't know how to model some good equations for this part, at least I have something.
Moments on sheaves: I did some modeling about the moments present on each sheave and for that I come up with a general equation:
J_o*\ddot{\theta}_n=[(\frac{T_1*(R+\mu*r)^{n-1}}{(R-\mu*r)^{n-1}})-(\frac{T_1*(R+\mu*r)^{n}}{(R-\mu*r)^{n}})]*R-(-1)^{n+1}*\mu*[(\frac{T_1*(R+\mu*r)^{n-1}}{(R-\mu*r)^{n-1}})+(\frac{T_1*(R+\mu*r)^{n}}{(R-\mu*r)^{n}})]*r
where n = sheave number from the first image (not the number or quantity of sheaves)
Forces on the Weight: For this modeling I use the third image.
m*a+K_1*y+K_2*y+K_3*y+K_4*y=0
In this case I might consider the stiffness equal in each wire segment but still when I think about this equation I get problems with the others.
Please I nee good help about the detailed modeling of this system, I guess it's complicated from a first point of view but maybe it's because of my lack of knowledge on this kind of modeling!
Thanks in advance!
"how can I model each sheave individually with different velocities?"
Consider the linear velocity of the cable and the radius of the pulley.
Thanks, I know that but the problem is to model the translational speed of the two sheaves attached to the weight, also, i guess that the sheave on the left of the weight has a higher angular velocity than its partner on the right of the weight!
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
