Detecting Falling Objects with a LiDAR
The discussion centers on using a LiDAR system to detect falling objects, with a scanning frequency of 100Hz and an angular resolution of 1°. The user is concerned about effectively detecting vertical falling objects while scanning horizontally, questioning the limitations of the LiDAR's scanning method. There is a suggestion to rotate the LiDAR vertically to improve detection capabilities. The user aims to identify objects thrown from heights, like balconies or bridges, while minimizing false positives, such as birds. The conversation highlights the potential advantages of using conventional cameras with image processing over LiDAR for this application.
daniel1211
I am experimenting with a LiDAR system, one of my goals is to detect falling objects. The scanning frequency is 100Hz with an angular resolution of 1°. I have been able to detect an object if it is a certain size or greater moving horizontally but I'm not sure what I should focus on to make sure that it will see an object falling vertical as it scans horizontal.
Where do the objects fall?
If you can just scan a narrow horizontal line, I guess you'll miss some objects that fall through faster than your scanning frequency.
rotate the LIDAR so it is vertical
do you need to detect speed of the falling object or just that it is there ?
if just that it is there ... why use a LIDAR ?
tell us more about what you are trying to achieve ... as in explain you project clearly
Dave
I would like to detect if objects are being thrown over a balcony, edge, bridge, etc... but I would also like to avoid false positives such as a bird.
in an open area ... that is going to be virtually impossible
Well, most birds have a motion different from falling objects, but I don't see why a LIDAR would be used. A conventional camera and some image processing looks easier.
Likes davenn
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
