Detecting Water Flow Through Pipe
To detect water flow through a pipe without submerging devices, several methods are suggested. One option involves drilling a small hole in the pipe and using a bag or tire pressure gauge to monitor changes indicating flow. Another approach is to check the pipe's temperature, as flowing water will be cooler than room temperature. Additionally, monitoring vibrations in the piping can signal water movement. Non-intrusive flow switches utilizing Doppler or ultrasonic technology are also recommended for reliable detection.
ssmith579
I'm looking for a way to detect water flow through a pipe. For example, I want to detect when a toilet flushes or leaks. I'm looking for a way to detect this that doesn't require anything submerged in the tank or inserted into the water line. I really just want to know that water is flowing I don't care about flow rate. Any suggestions would be appreciated.
Steve
The most reliable way would be to drill a tiny hole in the piping (PVC?) on the up side (away from the direction of gravity) and somehow tape a bag over top of the hole. The bag should inflate when there's flow. You could also just put a tire pressure gauge into the hole. Change in pressure would indicate flow. Just make sure both are secured so you don't cause a leak.
If the flow is constant you could check the pipe temperature. It should be a bit cooler than room temperature if it's house water. You could also check for any vibrations in the piping.
Not sure of your budget and other requirements, but you can use a "non-intrusive" flow switch based on the Doppler or Ultrasonic principle. Do an internet search for non intrusive flow switch and you will find many producs.
Wouldn't this cause it to flow all the time? :bugeye:
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 56 ·
  • · Replies 28 ·
