Determine for which x the derivative exists for $$f(x)=arcsin(\sqrt x)$$
The discussion revolves around the function $$f(x)=arcsin(\sqrt x)$$ and the determination of where its derivative exists. Participants are examining the relationship between the domain of the original function and the domain of its derivative, particularly at the endpoints of the interval [0, 1].
  • Participants are exploring whether the derivative exists at the endpoints of the domain and questioning the implications of differentiability at those points. There is discussion about the validity of using the domain of the derivative to determine where it exists and whether one-sided limits can be applied at endpoints.
The conversation includes various perspectives on the existence of the derivative at specific points, particularly at the endpoints of the interval. Some participants suggest that the derivative is undefined at these points, while others explore the implications of differentiability and the definitions involved.
Participants are considering the definitions of derivatives in relation to closed intervals and the potential for counterexamples that challenge generalized rules in differentiation. There is an acknowledgment of the need for careful reasoning when discussing the existence of derivatives at specific points.
tompenny
Hi there.
I have the following function:
I've caculated the derivative to:
$$f'(x)=\frac{1}{2\sqrt x\sqrt{ (1-x}}$$
And the domain of f(x) to: $$[0, 1]$$
And the domain of f'(x) to: $$(0, 1)$$
I want to determine for which x the derivative exists but I'm not really sure if I should use the domain of the original function or the derivative of the function?
Any help would be greatly appreciated:)
You can only differentiate a function at a point if it is defined at that point.
If ##f## is differentiable at ##0## what is the derivative?
But what I have hard to understand is that the function is defined at [0,1] but does the derivative exists at the endpoints?
the derivative at 0 is undefined right?
It looks that way.
I understand :) Thank you! Is it enough "proof" to show the derivative exists by calculating the domain of the derivative? or is there other ways?
You could argue that if the derivative of ##f## at ##x## exists then it must satisfy the equation you calculated. Therefore, the derivative at ##0## and ##1## cannot exist.
  • Love
You're not asked to prove anything. You know the domain of the function, and you have calculated the derivative of the function. The domain of the derivative of a function will always be a subset (possibly a proper subset) of the domain of the base function.
By examining the formula of the derivative, you can see that the points 0 and 1 will make the derivative undefined.
It's also useful to look at the graph of ##f(x) =\text{arcsin}(x)##.
If you're using the common definition of the derivative from Calc 1, then derivatives don't exist at the endpoints of a closed interval. When you take a limit, you have to be able to calculate the limit coming from both the left and the right (and they have to be equal). At an endpoint, you can only approach the point from one side. The limit of the difference quotient doesn't exist at an endpoint for this reason, so the derivative doesn't exist. To get around this technicality, you may define the derivative at an endpoint to be the one-sided limit.
A counterexample to this idea is:
$$f(x) = x^2\sin(\frac 1 {x^3}) \ \ (x \ne 0) \ \ \ \text{and} \ f(0) = 0$$
The derivative is:
$$f'(x) = 2x\sin(\frac 1 {x^3}) - \frac 3 {x^2}\cos(\frac 1 {x^3}) \ \ (x \ne 0)$$
It looks like the derivative at ##0## doesn't exist. Yet ##f'(0) = 0##.
I wasn't thinking in terms of piecewise-defined functions.
Is my argument in post #7 valid otherwise? I'm not entirely sure.
If applying the rules of differentiation leads to a result that isn't actually the derivative, wouldn't that imply that one or more of the theorems establishing the product rule, quotient rule, and chain rule is wrong?
I'm always wary about trying to come up with a generalized rule in mathematics. Unless I can prove an idea, I worry there's some sort of pathological counterexample I didn't think of.
One way your suggestion could lead to an error is with this function, for example:
$$f(x) = \frac{x^3-1}{x-1}.$$ It's not defined at ##x=1## so ##f'## doesn't exist at ##x=1## either. But a student will typically find ##f'## by first simplifying ##f## to ##x^2+x+1## and then differentiating. The expression ##2x+1## is clearly defined at ##x=1##, but it's not true that ##f'(1)=3##.
We'd have to find a way (other than by defining ##f## by a different formula at ##x = 0##) for the differentiation process to have to exclude ##x = 0##. Somehow to produce a formula for the derivative that explicitly has had to exclude ##x = 0##. But, when we look directly at the function, the derivative exists at ##x= 0##.
I must admit I can't see a way to do that.
haruspex said:
No, you can only say ##\lim _{x\to 0}f'(x)=0##, no matter which side you approach from. But the definition of a derivative at x requires that the function is defined at x.
The function is defined at ##x = 0##: ##f(0) = 0##
Sorry, missed that.
  • · Replies 105 ·
12K
