Determine sources being charged
  • Thread starter Thread starter mugzieee
    Charged Sources
The discussion revolves around a circuit analysis problem where the user struggles to determine which sources absorb positive power and to confirm that the algebraic sum of the absorbed power values equals zero. The user calculated power values of -4W, -16W, 40W, -50W, and -30W but could not achieve a sum of zero. Key issues identified include incorrect notation for current and voltage sources, leading to confusion in calculations. The user is advised to ensure that all sources are correctly labeled and drawn according to standard conventions.
  • Understanding of circuit analysis principles
  • Familiarity with power calculations in electrical circuits
  • Knowledge of independent voltage and current sources
  • Ability to interpret circuit diagrams accurately
  • Research the correct notation for voltage and current sources in circuit diagrams
  • Study Kirchhoff's laws for power and current in electrical circuits
  • Learn about parallel circuits and how to analyze them
  • Explore online resources or textbooks that clarify power absorption in circuits
Electrical engineering students, circuit designers, and anyone involved in circuit analysis and power calculations will benefit from this discussion.
mugzieee
i keep getting stuck in this problem, i don't see what I am doing wrong.
the problem says to determine which sources absorb positive power, then show that algebraic sum of the five absorbed power values is zero.
i have attached a picture of the circuit, and here is what i have done:
Starting from left to right,
p=-4W
p=-16W
p=40W
p=-50W
p=-30W
I am not getting the sum to equal 0.
From what i understand, when current is going from + to - in a independent voltage source it is charging and when it is going from - to + it is releasing power, and that is the guidelines i have used to get the bove answers. I am just not sure if I am supposed to follow the same guidelines for independent current sources. Is there a website that discusses these topics, kuz my book has not done a good job to demonstrate these ideas very clearly.
Yeah, something is nonsensical there. First of all, there is a really weird mixed notation for the sources. Some of them are drawn as current sources (with the arrow inside), but are labelled with a voltge. That's incorrect.
And if you correct the notation so that all sources labelled with a voltage are drawn as voltage sources, then you basically get three 10V voltage sources in parallel, with a single current source also connected in parallel. But the currents don't add up correctly in that case either, since you end up with different currents in different legs, even though they have the same voltage source in each.
Are you sure you have correctly drawn the circuit?
ya, I am positive that the circuit is drawn correctly, i just copied it straight out of the book...
But a current source with a voltage notation across it is not standard. Sorry that I'm not of more help.
its ok, I am just going to wait until the professor goes over the answer in class today. i mean that's the circuit the book has given us, so that's what I've been trying to work on. thanks for your help tho
  • · Replies 16 ·
