Determine the magnitude of the force on each charge
The problem involves two negative and two positive point charges, each with a magnitude of Q = 3.16mC, positioned at the corners of a square with side length a = 0.105m. The original poster seeks to determine both the magnitude and direction of the forces acting on each charge.
  • Mixed
  • The original poster calculates the magnitude of the forces and expresses confusion regarding the angles associated with each charge. Participants question the application of the tangent ratio and the specific charges to which it applies. There are attempts to assign angles to each charge, with varying results and discussions about the signs of the angles.
Participants are exploring different interpretations of the angle calculations and discussing the symmetry of the forces. Some guidance has been offered regarding the direction of the forces and the relationship between the angles and the positive x-axis. There is an ongoing examination of the correctness of the angle assignments.
There is mention of potential issues with the online platform used for submitting answers, including whether angles should be expressed in degrees or radians. The original poster has a limited number of attempts remaining for submitting answers.
meme177
1. The problem
Two negative and two positive point charges (magnitude Q = 3.16mC ) are placed on opposite corners of a square (side lengths a = 0.105m )
#1. Determine the magnitude of the force on each charge.
I GOT... F1,F2,F3,F4 =7.44x10^6N (which was marked correct)
I am having trouble with this question...
#2. Determine the direction of the force on each charge.
I know (Fy/Fx)=1
so tan-1(1)=45
Its asking for θ1,θ2,θ3,θ4 and I have no idea how to get the angles :(
Hello meme, and welcome to PF.
If you know the tangent, you know the angle (plus or minus pi), isn't it ?
However, the "I know (Fy/Fx)=1" applies to which of the charges, exactly ? How about the other three ?
And: have you altready defined what theta is ? Or was it given ?
θ1,θ2,θ3,θ4
I have tried these answers (in order)
225,225,225,225=WRONG (but then I was like NO this is impossible)
Then I tried
135,45,315,225=WRONG
I don't know what to do anymore
It can surely not apply to all four of them !
Charge #2 where I calculated the y and x component of the force for question #1
I think I see it! charge #2 is 45 ...Charge#1 (45+90=135)...charge#4 (180+45=225)...charge#3 (45+90=135) ??
Still a small matter of signs: my hunch for e.g. #2 is that two attracting forces from charges closer by overcome one repelling force from #4. From there, with symmetry considerations, all forces are towards the center of the square. Agree ?
okay, I agree.
with the forces all pointing to the middle, they cancel (no movement)
Now I have θ1= -45 θ2= -135 θ3= 45 θ4=135
Is this correct, now?
So theta is the angle wrt the positive x-axis.
I think you swapped 3 and 4 (in your post not in the drawing)
Movement doesn't apply here. The charges are positioned in fixed given places,
and there is no mention of how they are kept there...
Yes, so θ1= -45, θ2= -135, θ3= 135, θ4=45 ? Am I doing the angles wrt positive x-axis right?
Yes and yes, IMHO.
Do like charges attract, or do they repel?
@Sam: Meme is talking about the net forces, I should think. The magnitude was already calculated in part #1 of post #1.
Okey-Dokey .
Mastering Physics is still counting the angles wrong :/
Does M P want radians?
Otherwise M P may want you to specifically say, degrees, or ° .
no, the units are already there (degrees) counterclockwise from the +x axis
Here is how it looks
Maybe they want
θ1, θ2, θ3, θ4 =
315, 225, 135, 45
but I see you have only 2 tries remaining.
I got it! ... thanks guys!
That's good to hear.
M P really should have taken your answers with the negative angles. They give exactly the same orientation for the vectors.
Goes to show programmers and teachers are different, both only human.
Well done, meme and thanks for helping out, Sam.
M P should do something about this. All the physics was already in part A and part B is more like a detective to find out what their limited answer domain is.
