Determining appropriate range from test data
  • Thread starter Thread starter ChaoticLlama
    Data Range Test
ChaoticLlama
Hello all.
I am performing chemistry experiments and recording the times of various observed results. What I am doing currently is performing the test several times in order to determine what result is "normal."
My goal is to determine a range as a standard by which all future tests will be compared against. I do not know the correct expected time for these results; this will be set by my experiments.
Say for example we use this test data in seconds:
25
25
24
25​
The full range of data is 22 to 27 with the average being 25, But maybe the "acceptable" range should be 25-27.
I would like to know what tools I should use to analyze this data to determine statistically what range of data should be considered normal.
Thank you.
Hey ChaoticLlama.
One thing you can do is to use a distribution (i.e. a statistical one based on your sample, or if you make an assumption on the population), and look at the interval corresponding to the a/2 in each tail where 1-a corresponds to the probability that defines your interval.
A lot of people would use a normal distribution and then find the 95% interval for that distribution, but this isn't always right since not everything is always just the "default".
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
