Determining current drawn from a capacitor
  • Thread starter Thread starter Artlav
    Capacitor Current
To determine the current drawn from a supercapacitor, the user calculated the energy before and after connecting a load. With a 3000F capacitor starting at 1.100V and dropping to 1.045V over 3.5 seconds, the energy calculations showed a decrease of 177J. This resulted in an average power output of 50.5W, leading to an estimated current of 47.1A using the formula A=W/V. The method of using voltage drop and energy calculations is validated, confirming the accuracy of the current estimation.
Artlav
Hello.
I want to know what current i am getting out of a supercapacitor, but i have nothing to directly measure the currents in the given range with.
So i tried to determine it from the voltage drop on the cap, and i want to know if i did it right.
Given is 3000F capacitor, at initial voltage of V1=1.100V.
After being connected to the load in question for 3.5 seconds, the voltage is V2=1.045V.
Thus, the energy in the capacitor is 0.5*C*V*V.
E1=1815J
E2=1638J
Which gives spent energy of 177J.
W=J/s, so for the 3.5 seconds it was giving out 50.5W of power.
Finally, A=W/V, and average V was 1.0725V, which gives 47.1A of current.
Is that a correct way of current estimation?
You can also use a capacitor equation.
C = Q/V = (I*t)/V ---> I = C * V/t = 3000F * (1.1V - 1.045V)/3.5s = 3000F * 0.055V/3.5s = 47.14A
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
