Determining Quadratic and Cubic Functions with Integral Coefficients
  • Thread starter Thread starter Dough
    Calculus Gr
The discussion focuses on solving two mathematical problems involving quadratic and cubic functions with integral coefficients. For the quadratic function f(x), the properties provided include f(3/2) = 0, (x-2) as a factor, and f(4) = 50, leading to the conclusion that f(x) can be expressed as f(x) = a(x-2)(2x-3). For the cubic function g(x), the properties include g(3) = 0, g(-3/4) = 0, (x+2) as a factor, and g(1) = -84, resulting in the form g(x) = a(x-3)(4x+3)(x+2). Participants share their approaches and corrections, emphasizing the importance of correctly identifying factors and using given values to solve for constants. Overall, the thread highlights the step-by-step process of determining the functions based on provided conditions.
Dough
Well there are actually two questions i need some help with, if you could provide a full solution so i cna see the step by stpe thing it would be nice.
Question 1
A quadratic function f(x) with integral coefficients has the following properties:
f(3/2) = 0, (x-2) is a factor of f(x), and f(4) = 50. Determine f(x).
Question 2
A cubic function g(x) with integral coefficients has the following properties:
g(3) = 0, G(-3/4) = 0, (x+2) is a factor of g(x), g(1) = -84. Determine g(x).
Thanks!
You could begin by writing out a general (generic) quadratic function, e.g. y = ax2 + bx + c and then think how you could solve for a, b and c. Does that help to get you started?
i've written out what I've been given:
f(3/2) = 0 therefore (2x-3) is a factor of f(x),
Factors of f(x) = (2x-3) and (x-2)
f(4) = 50
i also wrote out ax^2 + bx + c as oyu suggested but not seeing a link... :(
whati s the general form of f(x) ??
quadratics look like f(x) = ax^2 + bx + c
ok from taht what is f(2) ?? Using the formula for f(x) above and your given info form equations using f(3/2) and f(4) as well to solve for a, b, and c.
Dough, follow stunner's suggestion. For example, how would you write f(4) in terms of f(x) = ax^2 + bx + c?
i did that but no luck i'll give it another shot, i make mistakes osmetimes so its possible i may have done somethign wrong whihc messed everythign else up...
Go ahead and post here what you've done.
yay, i got the first one... on the third try after the above post, i kept makign silly errors just now... i'll let you know how i do witht he the next one, thanks for the help :D
i don't think i got it right and it was hell of a lot of work... i might give it a shot tomorrow or later i got f(x) = -8x^3 - 50x^2 - 54x + 28
thanks tho i got one so i have teh idea now its just not makign stupid mistakes!
dry, we didnt even have to do number 3... i sitll try it agian later caus ei wanan find out how to do it!
By the way, Dough, I think you were doing the first problem in a better way than writing "f(x)= ax2+ bx+ c" as others were telling you. You are correct that since 3/2 is a 0 of f, 2x-3 is a factor. And you are told that x-2 is a factor. Since f is quadratic, the can't be any more factors involving x, only a constant:
f(x)= a(x-2)(2x-3). Now put x=4 in that, set it equal to 50 and solve for a.
Pretty much the same thing with question 2:
You know that 3 and -3/4 are zeroes of g (I presume that "G(-3/4)" was really "g(-3/4)" ) so that x-3 and 4x+3 are factors. You are told that x+ 2 is a factor. Those three factors will give a cubic so there are no other factors with an x. We must have
g(x)= a(x-3)(4x+3)(x+2) for some constant a. Since g(1) = -84, set x= 1, put it equal to -84 and solve for a.
