Determining the direction of electric field flow and the sign on potential difference
The discussion focuses on determining the direction of the electric field and the sign of the potential difference in a radial resistor with inner radius r1 and outer radius r2, characterized by conductivity sigma. The electric field points radially outward, aligning with the direction of current flow, which indicates a flow of positive charge. Consequently, the potential difference V2 - V1 is positive, as the potential drop occurs in the direction of current flow, consistent with Ohm's Law (E = IR).
  • Understanding of electric fields and charge flow
  • Familiarity with Ohm's Law and its applications
  • Basic knowledge of resistors and conductivity
  • Concept of potential difference in electrical circuits
  • Study the principles of electric fields in radial systems
  • Explore the relationship between current, voltage, and resistance in depth
  • Learn about the implications of conductivity on electric flow
  • Investigate potential difference calculations in various circuit configurations
Students in electrical engineering, physics enthusiasts, and anyone seeking to deepen their understanding of electric fields and potential differences in resistive materials.
StudentofSci
A resistor made from a shell with an inner radius r1 and an outer radius r2 hasa conductivity sigma. The current flows radially outward.
1.What direction does the E field point in.
2. Is the potential difference V2-V1 positive or negative.
None, problem is conceptual.
As far as I know the electric field flows towards an negative charge and away from a positive charge. I believe that the direction a current flow indicates a flow of positive charge. Thus if a positive charge is flowing outward then the electric field must also be flowing outward in order to move away from the positive charge.
The potential difference here I believe would also be positive. This is just because in problems that I've done before when it was positive the electric current was flowing outward. This however, may just be cowincedence. Can someone please explain this concept to me.
Thank you for your time.
Yes, it's basically Ohm's Law. When current flows through a resistance there is a potential drop in the direction of the current flow: E = IR.
  • · Replies 22 ·
