Determining types of interference
  • Thread starter Thread starter jaejoon89
    Interference
To determine whether two rays of light will interfere constructively or destructively, calculate the path difference between them. Constructive interference occurs when this path difference is an integer multiple of the wavelength. Conversely, destructive interference happens when the path difference is a half-integer multiple of the wavelength. If the path difference does not fit either condition, the interference will be partial, falling between fully constructive and fully destructive. Understanding these principles is crucial for analyzing light behavior in diffraction grating scenarios.
jaejoon89
How do you determine whether two rays of light will constructively or destructively interfere? Is it possible neither can occur?
I'm just trying to figure it out for the basic case where they are separated by 'd' in the diffraction grating and later meet up at a point.
My TA said you should divide the length of each ray or something and get a rational number, but that doesn't quite make sense.
First you would calculate the difference in path length for the two rays.
If the path difference is an integer multiple of the wavelength, the rays interfere constructively.
If the difference is a "half-integer" multiple of the wavelength, i.e.
(n + ½) λ, where n is an integer​
then the two rays interfere destructively.
If the path difference is anything else, the interference is somewhere in between fully destructive and fully constructive.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
