Can Pascal's Law Be Applied to Enhance Cycle Rickshaw Efficiency?
  • Thread starter Thread starter rohitjinnu16
    Cycle
Applying Pascal's Law to enhance cycle rickshaw efficiency involves using fluid-filled cylinders to create a gearing system that amplifies force from pedaling. However, this method may lead to significant energy loss due to the inefficiency of fluid dynamics in transferring energy. The discussion highlights that while leverage can be gained, the overall energy input remains the same, making it less advantageous than traditional gearing systems. Additionally, concerns are raised about the practicality and speed of the rickshaw, suggesting that it may not be a viable solution for efficient transportation. Ultimately, the proposed application of Pascal's Law may not yield the desired improvements in rickshaw performance.
rohitjinnu16
what if i use the pascals law for providing greater force,even by applying a small amount of force on the pedal.this larger force is used to drive the rear axle.shall i face any problems please suggest any difficulties even.
Um... What? How do you intended to apply Pascal's law to a pedal powered vehicle?
https://en.wikipedia.org/wiki/Pascal's_law
I suppose it is at least conceivable you would somehow use fluids in this fashion to construct the equivalent of some kind of gearing system. It would seem to be extremely complicated for a pedal powered vehicle.
Can you expand on what it is you are trying to do?
i am attaching 2 cylinders of different size (1 of smaller cross section than the other) with the 2 pistons facing out.so if we give drive to one piston using the slider crank mechanism(by pedalling) and obtain a rotary motion on the other side through the fluid.so driving the piston (smaller area of cross section) with little force we can generate a greater force on the other side using the pascals law.with this we can drive the rickshaw with a little effort.
Um...
Well, pistons full of fluid tend to use a lot of energy just to push back and forth. They may give you some leverage, but they are not exactly the most efficient at transferring energy. So, you will find you have to work quite hard to get the output you want.
You need to be looking up the First Law of Thermodynamics and considering it carefully. Even if you do get some kind of leverage, you still have to put in the same amount of energy. There is no particular advantage to using fluids to accomplish leverage as opposed to gears. And I'm having a lot of trouble imagining how you would arrange the pistons anyway.
Just one problem: your rickshaw's speed will be snail's pace; passengers will get out and walk.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
