astropi
- 47
First off, this is not for a course, I'm reviewing material. This also *should* be straightforward! I think I'm forgetting something simple, so if someone could point it out to me, I would be able to sleep easy tonight :)
OK! the question:
Given a matrix T = \begin{pmatrix}<br /> cosx & -sinx\\<br /> sinx & cosx\\<br /> \end{pmatrix}$
we want to find the inverse of {\bf S}^{-1}={\bf S} and then take STS^{-1}.
So first I find the eigenvalues which are cosx +/- isinx
Next I calculated the eigenvectors and got a(1) = (1,-i) [column vector]
and a(2) = (1,i) [column vector]
If you normalize the two eigenvectors you get a constant 1/sqrt[2] for both.
That gives me
S^{-1} = \frac{1}{\sqrt{2}}\begin{pmatrix}<br /> 1 & 1\\<br /> -i & i\\<br /> \end{pmatrix}$
and when I solve I get S = \frac{1}{\sqrt{2}}\begin{pmatrix}<br /> 1/2 & i/2\\<br /> 1/2 & -i/2\\<br /> \end{pmatrix}$
If you look above, you should see that I did most everything correctly (I believe, let me know if I made an error)! However, clearly STS^{-1} should give me back a matrix with my eigenvalues on the diagonal. However, I get an extra coefficient in front of the matrix which should cancel out. Where is the mistake? Also, along those lines, I read somewhere that S=(S^{-1})^{\dag} is this true? I was always under the impression that S is simply the inverse and you do not need to take the adjoint?
