Diff Equation with one solution?
  • Thread starter Thread starter >Modx<
>Modx<
Hi guys, my question is from a book on differential equation. It asks me to give a differential equation that has only a trivial solution, y = 0.
I give it some thought and I can only think of a diff eq'n of y' = y, however, in this case y = e^x will also be a valid solution but not a trivial one. So I am not so sure if this is what the question wants, or there is a diff eq'n that has only one solution which is y =0. Thank you in advance.
Well, you said "y = 0", isn't that a valid answer?
If you insist that it contains derivatives of higher order than 0, you can easily adapt it (but you need boundary conditions).
y' = y; y(0) = 0
This initial-value problem has only one solution.
Oh ok ... that will do ... Thank you Mark44 and CompuChip.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
