Difference between Impulse and Momentum
Impulse and momentum are closely related concepts in physics, where impulse refers to the change in momentum resulting from a force acting over time. When a force is applied to an object for a short duration, it imparts an impulse, which alters the object's momentum. The relationship can be expressed mathematically as impulse equaling the integral of force over time, while momentum is defined as mass times velocity. Both impulse and momentum are vector quantities, and their connection is encapsulated in the impulse-momentum theorem, which states that the change in momentum equals the impulse applied. Understanding this relationship is crucial for analyzing motion and forces in various physical scenarios.
Jadaav
What's the difference between impulse and momentum ?
When do we use impulse or when do we say a body has impulse ?
Hello.
If a body experiences an impulse, its momentum changes. So if a force acts on an object in a short amount of time, that object will experience an impulse, and subsequently its momentum will change.
Likes AhmeddKhaleed7
momentum is a property of moving objects...mass x velocity.
To change momentum requires a force acting for a length of time.
The quantity Force x time is called impulse and it equals the change in momentum.
So I would say impulse is used to link force with momentum.
Likes abbasiharis and Jadaav
F = ma, where a = Δv/Δt. Therefore FΔt = mΔv.
The left hand side is the impulse and the right hand side is the momentum. Both are vector quantities.
technician and mark.watson both are on the right track, but I would say technician is assuming a constant force, while mark.watson is giving an infinitesimal form of the actual definition:
The definition of impulse I is
\vec{I}=\int \vec{F} \ dt Impulse is a time integral of force.
Momentum, on the other hand, is a property of an object. If an impulse I is imparted on an object, it will change that object's momentum by \vec{I}. To be more explicit, if the object initially has momentum \vec{p}, and then an impulse \vec{I} acts on that object, its final momentum will be \vec{p}+\vec{I}. So an impulse is basically momentum transferred.
Impulse is to momentum as work is to kinetic energy.
Work-energy theorem: ΔK = W (the change in an object's kinetic energy equals the work done on it)
Impulse-momentum theorem: Δp = I (the change in an object's momentum equals the impulse acting on it)
Likes 1 person
Well, work can go into potential energy too, e.g. stretching a spring.
Likes 1 person
Thanks a lot guys :)
  • · Replies 35 ·
