Difference between live, neutral, ground and common in electrical circuits
9 replies · 16K views · last reply
shintashi
OK, so I've gone through probably 90 tutorials on electricity and related topics, and there's a bundle of terms I ran into, used by people ages 12-80 with a dozen different accents and twice as many time zones. (So I'm not sure how many terms are universal and how many are provincial).
Live, Common, Ground, Neutral, R/S-Terminal, and Switch line.
I have my own extremely limited understanding of Live (power flowing, right? is that an AC term only or does it also apply to DC?), and Vaguely understand Ground to be attaching a third wire to an object with low resistance to act as a place for electrons to seek to be at their most rested Disney Land like state of well being (I like that analogy better than the one about tortured electrons fleeing for their lives).
But Neutral and Common? Are those variations of Ground? And R Terminal? Switchline?
Are there terms I missed? When I do a circuit, it seems like there's only 3 wires, so why have 6+ terms?
hi there
this subject has been thrashed to death on this forum... there are a number of references at the bottom of the page to some of those threads
here's some basics
Live ( also known as Hot or Active) and Neutral are usually ALWAYS related to AC power systems
Common and negative are usually the same in a single rail DC power supply
BUT in a dual rail PSU, you can have, say a, +12V, 0V ( common) and a -12V
Ground has various meanings depending on what electronics school institute you attended
Ground generally refers to the "common", "negative" or 0V rail of a PSU or piece of circuit
There are several common references to "ground" in circuits
chassis ground ( connected to the metal case), this may also constitute an EARTH ground that is also
connected to actual Earth via the PSU and the mains Earth wire
cheers
Dave
not sure about these terms specifically ... please clarify where you read these and in what context
Dave
I'm going to guess "switch line" is some kind of hybrid jargon of "line" and PSU switch, or some other switch. R Terminal probably came out of automotive circuits.
http://www.mightyram50.net/vbulleti...cal+System:The+Starter+plus+R+and+S+Terminals
So to clear things up, Common can be negative in DC, and ground in AC?
So Neutral is also Negative in DC, and also ground in AC?
Which means Neutral = Common? Is this never untrue?Chassis Ground is the version of ground I'm most familiar with.
"Can be" as in "Could be".
Every author ought to define the terms he's going to use in his presentation.
If you try to lock your mind into fixed meanings of the terms Common, Ground, and Neutral you'd better keep them general because different authors working in different fields use them differently.
"Common" usually means the point (node) in a device where the currents returning from various sections of the device all join up to get back into the power supply.
They might be returning to the positive side of the supply if for example the device is built with PNP transistors.
More often they will be returning to the negative side, which is a holdover from vacuum tube days.
In a split supply system as often used with op-amps "Common" is usually the junction of the positive and negative supplies.
Really it's up to the draftsman who draws the schematic to decide what point he is going to call "Common".
"Neutral" is most often used in AC power distribution. In that field it means the conductor carrying current back from a load to the source.
In US residential wiring the neutral is connected to Earth near the service entrance .
In industrial wiring the neutral may or may not be so earthed.
Neutral is NOT the "Ground" wire in residential wiring, Neutral is the white wire and it carries load current.
There's a green wire for Ground and it carries current ONLY if something went wrong and allowed current to get into the ground wire by accident. Its purpose is to prevent electrocution.
Do not confuse the two terms.
"Neutral" in DC is an unusual use of the term and you will have to figure out what was meant by whoever mentioned it .
No. Neutral is NOT Ground in AC distribution even though in your house wiring it's connected to earth.
It's sometimes true.
The complicated world will not bend to our preference for simplicity.
Read those old threads we suggested.
It really is a simple concept once we "get our thinking straight" (old Southern saying).
But "Ground" is the most misunderstood concept in EE. Get it straight now and you'll be way ahead.
IEEE 142 , the Green Book , is a great introduction.
old jim
There is your main problem, I think. The Power is no more flowing in the live than in the neutral, in a single phase system. The power flows because of the currents and voltages associated with all the conductors and not just one. That statement looks long winded but it takes account of what goes on with three phase systems.
You will often find conflicting terminologies amongst the various articles and books you may read. However, if you read an article (a reputable one) then there will be some definitions given (perhaps in a diagram) and that is what will apply consistently to that particular article. Hopping between articles and just looking at the terms used is risky and won't help your understanding. This is a modern problem, of course. Articles that you can get on-line can be full of absolute rubbish - especially those that claim the 'simplify' the topic - and you cannot rely on them. That can even apply to some of the posts on PF!. A textbook (on-line or paper) is a far more reliable source.
I was unaware it had a name R , but i learned about it on my 1953 Ford which was a 6 volt system.
There exists a "Ballast Resistor" whose purpose is to set the current through ignition coil while points are closed. They want a couple amps...
When you're starting the car battery voltage drops because the starter pulls so much current, maybe clear down to 4 volts.
That causes spark to be weak right when you need it most.
So the starter solenoid on old 6 volt Fords , which is mounted on the fenderwell adjacent battery, has a contact that bypasses the ballast resistor during starting , to give a hotter spark while cranking.
Ford kept that feature with its 12 volt cars .
Your description of the Dodge starter describes the same feature but the solenoid is mounted on the starter instead of the fenderwell.
I have no idea why they call it the R terminal. Maybe the first letter of some German word for that function ?
I have no idea if it's called R on other makes.
Understand the principle and the jargon becomes unimportant. A relay by any other name will switch as sweet.
It should be called "Chassis" not "chassis ground".
Chassis is insulated from "Ground" by the tires ( in England, from Earth by the tyres) .
