Maximum Volume of Folded Box: Proving and Solving Using Differentiation
  • Thread starter Thread starter Mmx
The discussion revolves around a math problem involving a rectangular zinc sheet measuring 30 cm by 16 cm, from which equal squares of size x cm are cut from each corner to create an open box. The first part of the problem requires proving that the volume of the resulting box can be expressed as V = 4(x^3 - 23x^2 + 120x) cm³. The second part involves finding the maximum volume of the box using differentiation techniques. Participants share hints on calculating the box's dimensions and applying differentiation to find maximum and minimum values. The conversation highlights a collaborative effort to clarify the mathematical concepts involved in the problem.
Mmx
Sorry my maths question is in Malay ill try to translate as gd as i can. I realyl have no idead how to do it.
A zink which have a square size of 30 cm x 16 cm.
At the end of the 4 edge of the sqaure zink is cut out equally same sides x cm.
After cutting the zink is fold into a a open box.
a) Prove that the volume, V of this box is equal to V=4(x^3 - 23x^2 + 120x)cm^3
b) After that, find the maksimum volume, V
If you can understand then nvm cause my maths are in malay and not english. In malay this topic are call Pembezaan I am not sure in english that is call differences. I can understand better with the look of working. Sorry:cry:
Okay, I think I understand what you mean...
Do you know the formula for computing the volume of a box: \mbox{V = length x height x depth} = \mbox{A_{base}} \mbox{ x height}?
So after you fold that zink into an open box, what's the length, the depth, and the height of that box?
So, your zink will look like this:
__|¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯|__
¯¯|_______________|¯¯
Hint, the base is the rectangle in red. Can you find its area?
Can you find the height of the box?
From there, can you find its volume?
For number 2, do you know how to differentiate?
For example f(x) := x3 + x
=> f'(x) = 3x2 + 1.
Can you do this?
If yes, then do you know how one can find an maximum value and minimum value of a function by differentiation?
Thx. Yes i know how to differentiate that's y my malay call Pembezaan. Thx for the hint. I Can do it now.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
