Differential equation after using Euler-Lagrange equations
4 replies · 3K views
Zaknife
Particle is moving along the curve parametrized as below (x,y,z) in uniform gravitational field. Using Euler- Lagrange equations find the motion of the particle.
[tex]\begin{array}{ll} x=a \cos \phi & \dot{x}= -\dot{\phi} a \sin \phi \\<br /> y=a \sin \phi & \dot{y}=\dot{\phi} a \cos \phi \\<br /> z=b \phi & \dot{z}= b \dot{\phi} \\<br /> \end{array}[/tex]
Lagrangean will be :
[tex]L=T-V=\frac{m}{2}\dot{\phi}^{2}(a^{2}+b^{2})-mgb\phi[/tex]
Using Euler-Lagrange equations we obtain:
[tex]\frac{d}{dt}\left(\frac{\partial \mathcal{L}}{\partial \dot{q_{l}}}\right)-\frac{\partial \mathcal{L}}{\partial q_{l}}=0[/tex]
[tex]m\ddot{\phi}(a^{2}+b^{2})+mgb=0[/tex]
How to deal with such differential equation ?
So [itex]\phi[/itex] is the only generalised co-ordinate, and all the other letters are constants, right?
In that case, this is a differential equation of the form [tex]\ddot\phi = c[/tex] which gives a simple linear solution (which makes sense, because the only freedom you have is how fast you move along the curve).
Zaknife said:
So all i need to do is double integration ?
That's correct. Write the equation in the form suggested by CompuChip and then integrate twice with respect to time. Since the right side is a constant is pretty simple to do.
The particle is moving along a helix (on a circular cylinder) with constant angular velocity. Therefore the angle in the plane xOy depends quadratically on time.
