Differential Equation - Initial Value Problem
14 replies · 3K views
cse63146
Solve the following IVP:
[tex]\frac{dy}{dt} = \frac{1}{2y+3}[/tex] y(0) = 1
[tex]\Rightarrow \int 2y + 3 dy= \int dt[/tex]
[tex]\Rightarrow y^2 + 3y= t +c[/tex] where C is a constant
Kinda stuck now. Any hints?
If I am understanding the problem correctly, all you have to do is plug in the values for y and t given by the problem text and solve for C.
to get your constant c, put in the value of y at t = 0 i.e y(0) = 1,
we have 1 + 3(0) = 0 + c implies c = 1. Thus you get a quadratic equation, then you can solve for y from there
cse63146 said:
wouldnt it be 1^2 + 3(1) = 0 + c => c = 4?
I do believe you are correct
so its:
[tex]y^2 + 3y = t + 4[/tex]
[tex]y^2 + 3y - 4 = t[/tex]
[tex](y + 4)(y - 1) = t[/tex]
stuck again
Oh, sorry for the mistake. But i know you got what i mean't
cse63146 said:
so its:
stuck again
solve [tex]y^2 + 3y -(t + 4) = 0[/tex]
using the general formula for quadratic equation. you y as a function of t
So would the general solution be y^2 + 3y = t + c and the unique solution be y^2 + 3y = t + 4?
I don't think that's it.
Does (0, 1) satisfy your unique solution?
Does your relation satisfy the differential equation? (You'll need to differentiate implicitly if you use y^2 + 3y = t + 4.)
If the answers to both questions are "yes" you have the unique solution.
the general solution is y^2 + 3y = t + c because simply it satisfies the differential equation.(check)
It will be unique if it satisfies the following
1. dy/dx is continuous in the given interval which contains the initial point
2. if Lipschitz condition is satisfied.
y has two roots when you solve the quadratic equation provided the discriminant is not zero. thus the solution of the differential equation is not unique
My stupidity knowns no bounds.
After applying the quadratic formula, I got the following:
[tex]y(t) = \frac{- 3 + \sqrt{9 + 4(t+4)}}{2}[/tex] and [tex]y(t) = \frac{- 3 - \sqrt{9 + 4(t+4)}}{2}[/tex]
at time t = 0
[tex]y(t) = \frac{- 3 + \sqrt{9 + 4(0+4)}}{2} = 1[/tex] which satisfies the IVP, while [tex]y(t) = \frac{- 3 - \sqrt{9 + 4(0+4)}}{2} = -4[/tex] which doesn't satisfy the IVP.
Therefore:
[tex]y(t) = \frac{- 3 + \sqrt{9 + 4(t+4)}}{2}[/tex] is the correct answer.
at time t = 0
Therefore:
Thus, you now know your general solution and the unique solution which satisfies the I.V.P.
Still can't believe it took me that long to figure it out.
Thanks for putting up with me.
