Differential Equation - Initial Value Problem
In summary, the student is stuck trying to solve an IVP involving y(t)=-3 and y(t)=-4. The student finds the general solution of y(t)=-3+3sqrt9+4(t+4) and the unique solution of y(t)=-4.
cse63146
452
Solve the following IVP:
[tex]\frac{dy}{dt} = \frac{1}{2y+3}[/tex] y(0) = 1
[tex]\Rightarrow \int 2y + 3 dy= \int dt[/tex]
[tex]\Rightarrow y^2 + 3y= t +c[/tex] where C is a constant
Kinda stuck now. Any hints?
If I am understanding the problem correctly, all you have to do is plug in the values for y and t given by the problem text and solve for C.
dont I need the left side to be y(t)?
to get your constant c, put in the value of y at t = 0 i.e y(0) = 1,
we have 1 + 3(0) = 0 + c implies c = 1. Thus you get a quadratic equation, then you can solve for y from there
wouldnt it be 1^2 + 3(1) = 0 + c => c = 4?
I do believe you are correct
so its:
[tex]y^2 + 3y = t + 4[/tex]
[tex]y^2 + 3y - 4 = t[/tex]
[tex](y + 4)(y - 1) = t[/tex]
stuck again
Oh, sorry for the mistake. But i know you got what i mean't
cse63146 said:
so its:
stuck again
solve [tex]y^2 + 3y -(t + 4) = 0[/tex]
using the general formula for quadratic equation. you y as a function of t
So would the general solution be y^2 + 3y = t + c and the unique solution be y^2 + 3y = t + 4?
I don't think that's it.
Does (0, 1) satisfy your unique solution?
Does your relation satisfy the differential equation? (You'll need to differentiate implicitly if you use y^2 + 3y = t + 4.)
If the answers to both questions are "yes" you have the unique solution.
the general solution is y^2 + 3y = t + c because simply it satisfies the differential equation.(check)
It will be unique if it satisfies the following
1. dy/dx is continuous in the given interval which contains the initial point
2. if Lipschitz condition is satisfied.
y has two roots when you solve the quadratic equation provided the discriminant is not zero. thus the solution of the differential equation is not unique
My stupidity knowns no bounds.
After applying the quadratic formula, I got the following:
[tex]y(t) = \frac{- 3 + \sqrt{9 + 4(t+4)}}{2}[/tex] and [tex]y(t) = \frac{- 3 - \sqrt{9 + 4(t+4)}}{2}[/tex]
at time t = 0
[tex]y(t) = \frac{- 3 + \sqrt{9 + 4(0+4)}}{2} = 1[/tex] which satisfies the IVP, while [tex]y(t) = \frac{- 3 - \sqrt{9 + 4(0+4)}}{2} = -4[/tex] which doesn't satisfy the IVP.
Therefore:
[tex]y(t) = \frac{- 3 + \sqrt{9 + 4(t+4)}}{2}[/tex] is the correct answer.
at time t = 0
Therefore:
Thus, you now know your general solution and the unique solution which satisfies the I.V.P.
Still can't believe it took me that long to figure it out.
Thanks for putting up with me.
What is a differential equation?
A differential equation is a mathematical equation that relates a function with its derivatives. It expresses a relationship between a function and its rate of change, and is often used to model real-world situations in science and engineering.
What is an initial value problem?
An initial value problem is a type of differential equation that involves finding the solution of a differential equation that satisfies a given set of initial conditions. These initial conditions specify the value of the function at a certain point or points.
What is the order of a differential equation?
The order of a differential equation is the highest derivative present in the equation. For example, a first-order differential equation contains only first derivatives, while a second-order differential equation contains second derivatives, and so on.
How is a differential equation solved?
There are various methods for solving differential equations, such as separation of variables, integrating factors, and power series. The method used often depends on the type and order of the differential equation, as well as the initial conditions given.
What are some real-world applications of differential equations?
Differential equations are used in many fields, including physics, biology, economics, and engineering. They can be used to model and predict various phenomena, such as population growth, heat transfer, and fluid dynamics.
