Differential Equation of a hemispherical bowl
The discussion revolves around solving a differential equation that models the water level in a hemispherical bowl with a hole at the bottom. The equation is given as π(Ry - y²)(dy/dt) = -π(a10⁻²)²√(2gy), where g is the acceleration due to gravity. Participants suggest separating variables to facilitate integration, with some confusion about the integration process. Clarifications are provided on how to manipulate the equation into a more manageable form for integration. Ultimately, the focus is on finding the implicit function of y in terms of t through proper integration techniques.
jamesbob
A hemispherical bowl has a radious of R (metres) and at a time t = 0 is full of water. At that moment a circular hole of radius a (centimetres) is opened in the bottom of the bowl. Let y be the vertical height of the water above the hole at time t. Then y is governed by the differential equation
\pi(Ry-y^2)\frac{dy}{dt} = -\pi(a10^{-2})^2\sqrt{2gy},​
where g = 9.8m/s^2 is gravity.
Solve this differential equation to find y as an implicit function of t.
I need help with this. I am unsure of how to start. Do i try gather all the y terms on one side and everything else on the other?
Do you notice the equation is separable, so that f(y)dy = Cdt for some constant C?
Yes, can i say:
\frac{(Ry-y^2)dy}{\sqrt{2gy}} = \frac{-\pi(a10^{-2})^2dt}{\pi} ?
Now you should be able to integrate both sides (don't forget the constant of integration afterwards).
I've merged the old thread into this one.
im having difficulty integrating this. how do i get it into a form that is managable or atleast more recognisable??
thanks
You have
(Ry-y^2)dy/sqrt(2gy) = Rydy/sqrt(2gy) - y^2dy/sqrt(2gy). Reduce the fractions, and you should be able to find the antiderivative of each term. Does that help?
um kinda. I am not 100% sure on integrating them.
would i get:
\frac{2Ry^2}{\sqrt{2gh}} = \frac{3y^2}{\sqrt{2gh}} ??
would i get:
Where did "h" come from?? There was no h in anything you wrote before.
Before, you had
= \frac{1}{\sqrt{2g}}\left(Ry^{\frac{1}{2}}- y^{\frac{3}{2}}\right)dy
That should be easy to integrate.
  • · Replies 33 ·
