Differentials - is this valid or just sloppy but right?
In summary, The proper time is defined by d\tau^2=g_{\mu\nu}dx^\mu dx^\nu and it can be expressed as d\tau=\sqrt{dt^2-dx^2}=dt\sqrt{1-\frac{(dx^2)}{(dt^2)}}=dt\sqrt{1-\left(\frac{dx}{dt}\right)^2}. This can be considered rigorous by integrating the volume form on the worldline using the parameter d\lambda."
pellman
684
[tex]d\tau^2=g_{\mu\nu}dx^\mu dx^\nu[/tex]
Suppose we have flat space time with one space dimension.
[tex]d\tau=\sqrt{dt^2-dx^2}[/tex]
[tex]=dt\sqrt{1-\frac{(dx^2)}{(dt^2)}}[/tex]
[tex]=dt\sqrt{1-\left(\frac{dx}{dt}\right)^2}[/tex]
Can this be rigorous?
Regard [itex]x[/itex] as [itex]x(t)[/itex], then [tex]d(\ x(t)\ )=\left(\frac{dx}{dt}\right)dt[/tex]
Nothing wrong with juggling differentials --- just realize that they don't always obey the same algebraic rules as reals or complex numbers, which is sensible, since they're not. See non-standard analysis: http://en.wikipedia.org/wiki/Non-standard_analysis
And something I only just noticed. From [tex]d\tau=\sqrt{dt^2-dx^2}[/tex] we see that one cannot express [tex]d\tau[/tex] in terms of first order changes in t and x. That is, there are no numbers A and B such that [tex]d\tau=Adt+Bdx[/tex]. The slope of the graph of [tex]\sqrt{x^2}[/tex] is singular at x=0. There is probably something significant for the proper time concept here.
Let's just say that [tex]d\tau=\sqrt{dt^2-dx^2}[/tex] is short hand for the volume form on the worldline, i.e., it has no meaning until you integrate it. Let us write
[tex]{\omega} = \sqrt{ \left( \frac{dt}{d\lambda}\right) ^2- \left(\frac{dx}{d\lambda}\right)^2} d\lambda[/tex]
Here [tex]d\lambda[/tex] is a oneform. If you integrate this quantity over the parameter [tex]\lambda[/tex] you will get the volume of the wordline, or, more informally it's arclength.
Do you mean to ask if it is rigorous? If so then yes, it is rigorous.
Pete
Pete
Well... besides not being well defined =) I don't think you'll find any mathematician that would put their name to it =). It's just shorthand.
1. What is the purpose of differentials in mathematics?
Differentials are used to measure small changes in a function or variable. They are commonly used in calculus to calculate the rate of change or slope of a curve at a specific point.
2. How do differentials differ from derivatives?
Differentials and derivatives are closely related concepts, but they have different meanings. A differential is the infinitesimal change in a function, while a derivative is the rate of change or slope of a function at a specific point.
3. Can differentials be used to approximate values of a function?
Yes, differentials can be used to approximate the value of a function at a specific point. This is known as the first-order approximation or the tangent line approximation.
4. Are differentials always valid in mathematical calculations?
Yes, differentials are always valid in mathematical calculations. However, they may not always be the most precise or accurate method for finding the value of a function.
5. Is it considered sloppy to use differentials in mathematical equations?
No, using differentials in mathematical equations is not considered sloppy. In fact, it is a common and accepted practice in calculus and other branches of mathematics.
