Differentiating (v^3-2v*squareroot v): A Try
  • Thread starter Thread starter Altami
    Differentiating
The discussion revolves around differentiating the expression (v^3 - 2v*sqrt(v)) and its connection to a related problem involving the quotient of this expression by v. The subject area is calculus, specifically focusing on differentiation techniques and the application of the power rule and quotient rule.
  • Mixed
  • Participants explore the differentiation of the expression, with some correctly identifying parts of the derivative while others express confusion about differentiating square roots. There are discussions about applying the power rule and chain rule, as well as the potential simplification of the expression before differentiation.
Some participants have provided guidance on how to approach the differentiation, including suggestions to simplify the expression. However, there is a lack of consensus on whether to use the quotient rule or to simplify first, leading to varied interpretations of the problem.
There are references to specific instructions from a teacher regarding the use of the quotient rule, which some participants feel may have limited their thinking about alternative methods. Additionally, there is mention of confusion stemming from the presence of the square root in the expression.
Altami
How would you differentiate, (v^3-2v*squareroot v)?
would it look like...3v^2 - v^-1/2 ?
The 3v^2 part is correct! But how did you obtain v^-1/2??
Ah, see that's the thing how to you differentiate a square root? I have no idea?
Well, [tex]\sqrt{x}=x^{1/2}[/tex], so you just need to apply the power rule!
But the problem is that you don't only have a square root, you have [tex]v\sqrt{v}[/tex]. To derive this, you have to apply the chain rule. (or if you know your algebra, you could notice that [tex]v^{3/2}=v\sqrt{v}[/tex] and immediately apply the power rule)...
Well okay, I wanted to see if by understanding how to derive squareroot v, I could understand a much bigger problem.
The actual problem that is connected is this
y=(v^3 - 2v*square rootv)/ v
and I have to differentiate it, I know I have to use the quotient rule and I have tired but the dang square root is cause me problems.
Can't you just cancel v from the numerator and denominator??
I don't think so, I haven't tried that I know the answer...because it is...(2v-1)/squareroot2
But I don't know how to get to that, I've tried everything...that I know of...and I still can't get that answer...
so if someone could show me? maybe a step by step...cause I have wasted a while on this one problem...
So, nobody has an idea?
No, you don't have to use the quotient rule if you simplify this first.
[tex]y = \frac{v^3 - 2v\sqrt{v}}{v} = v^2 - 2\sqrt{v} = v^2 - 2v^{1/2}[/tex]
How can I vote you to be a life saver? Thank you so much, for some reason my teacher told me I HAD to use the quotient rule and I guess that blocked me to thinking of other ways! Thank you so much, your a life saver!
Well, if the instructions are that you have to use the quotient rule, then I haven't been any help at all. If so, I would write the numerator as v3 - 2v3/2.
Well, I meant that he didn't really give us clues as to have other ways of solving them, your were a great help. I still had to differentiate the final answer which you gave me, but I was able to do that no problem. Thank you anyways, again you did help me.
  • · Replies 33 ·
  • · Replies 18 ·
