Differentiation anomoly-in need of setting straight
  • Thread starter Thread starter DyslexicHobo
    Differentiation
The discussion revolves around a calculus problem involving implicit differentiation of the equation x + y = xy. The user initially attempted to simplify the equation to y = x/(x-1) but found discrepancies in the derivative answers. After further analysis, it was clarified that the answers derived from implicit differentiation were equivalent, differing only by a factor of -1. The user realized that both methods yield the same result when properly substituted, leading to a resolution of their confusion. Overall, the thread emphasizes the importance of careful differentiation and recognizing equivalent expressions.
DyslexicHobo
Differentiation anomoly--in need of setting straight!
I was studying for the AP calculus exam when I came across this question, which seems to have multiple answers. I cannot seem to find what is wrong with it (nor can my calc teacher).
Find dy/dx if x + y = x * y
I went about this problem the "easy way out". Instead of implicitly differentiating, I figured I could do some algebra to simplify it to y = x / (x-1). I saw the answers, and only one of them did not have a "y" in the answer, so I picked that one. It was wrong.
When solved implicitly, a different answer is found: (y-1)/(1-x). This is STILL different than what our answer key has, which is (1-y)/(x-1).
Can someone please help resolve this? Thanks!
Mathematics news on Phys.org
What ever other problems you're having:
contains a mistake on your part. The two answers written there are the same.
If you differentiate y=\frac{x}{x-1}, you get \frac{dy}{dx}=\frac{(x-1)-x}{(x-1)^2}.
Divide by \frac{x-1}{x-1}: \frac{dy}{dx}=\frac{1-\frac{x}{x-1}}{x-1}
Substitute y=\frac{x}{x-1}: \frac{dy}{dx}=\frac{1-y}{x-1}
No... it's just negative on the top and bottom. Multiply your answer by 1 = -1/-1 and see what you get
DyslexicHobo said:
I went about this problem the "easy way out". Instead of implicitly differentiating...
Isn't implicit differentiation "the easy way"?
1 + dy/dx = y + x dy/dx
1-y = (x-1)dy/dx
dy/dx = (1-y)/(x-1)
1-y = (x-1)dy/dx
dy/dx = (1-y)/(x-1)
What I meant is that, because I could see that it simplified to y = *stuff with no y*, I figured that dy/dx MUST not have a y in it. There was only one choice without one, so I chose that. It was the easy way out because I did not do any differentiating at all.
Also, I figured out my problem. Both answers were the same, but had a "y", and the other did not. When a substitution was made for "y", the answers were identical.
And yeah... I can't believe I didn't notice that the answer simply divided by a factor of (-1). Wow I feel dumb! :-P
All here is well, thank you for the help.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
