Differentiation of a Quotient check
The discussion focuses on differentiating the function S = (8x^2 - 7x + 125)/(8x + 7) using the quotient rule. The user initially presents their attempt at the solution, calculating derivatives for u and v, and applying the quotient rule formula. They receive feedback suggesting clearer use of parentheses to avoid confusion in the calculations. A specific error is pointed out regarding the simplification of terms, particularly the handling of the term 112x. Ultimately, the user confirms that their final answer is correct after clarification.
DBeckett91
S = (8x^2 - 7x + 125)/(8x+7)
Where the value of x is unknown
u = 8x^2 - 7x + 125 du/dx = 16x - 7
v = 8x + 7 dv/dx = 8
ds/dx = (v*du/dx - u*dv/dx)/v^2
= (8x+7*16x-7 - 8x^2-7x+125*8)/(8x+7)^2
= (128x^2 - 56x + 112x - 49) - (64x^2 - 56x + 1000)/(8x+7)^2
= (128x^2 + 56x - 49) - (64x^2 - 56x + 1000)/(8x+7)^2
= (64x^2+951)/(8x+7)^2
This rule I'm not very comfortable or confident with so if I have gone wrong anywhere in my equations any help would be much appreciated
You would do better to use parentheses:
[(8x+7)(16x- 7)- (8x^2- 7+ 125)(8)]/(8x+ 7)^2
and here you mean [(128x^2 - 56x + 112x - 49) - (64x^2 - 56x + 1000)]/(8x+7)^2
The only difference between this and the previous line is that the "112x" is missing. What happened to it?
In the above line there is -56x and +112x so all I did was 112x-56x to gain +56x, it was just some simplification of the equation so I had fewer numbers to work with later on
Oh, I see. Yes, that is the correct answer.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
