Differentiation of surface area of a right cylinder
tmlrlz
The total surface area of a right circular cylinder is given by the formula A = 2pir(r + h) where r is the radius and h is the height.
a) Find the rate of change of A with respect to h if r remains constant.
b) Find the rate of change of A with respect to r if h remains constant.
c) Find the rate of change of h with respect to r if A remains constant.
A = 2pir(r + h)
I thought i had this all right but then realized that what i had done for part a was wrong, i think that part b and c are right but i will just put my answers up to check.
a) A = 2pir(r + h)
r = c (constant)
A = 2pic(c + h)
A = 2pi(c2 + ch)
A/2pi = c2 + ch
however, i do not know at this point, how i would isolate c!
What i did was bring the A/2pi over and get c2 + ch - A/2pi = 0 and use the quadratic formula. From that i got that c = (h +- h)/4pi and reason that c cannot be zero or else the surface area would be zero so c must be h/2pi. I think that this process of my work is wrong because i don't think you can use the quadratic formula and solve for c because c is a constant.
We know that
A = 2pic(c + h)
A = 2pic2 + 2pich
dA/dh = 2pic = 2pi(h/2pi) = h
As you can see i don't think that what i did was correct, please help me with this one, a) is what i need most help with
b) h = c (constant)
A = 2pir(r + c)
A/2pir = r + c
c = (A/2pir) - r
dA/dr = 2pi(r + c) + 2pir = 4pir + 2pic = 4pir + 2pi((A/2pir) - r) = 4pir + A/r - r
c) A = c (constant)
c = 2pir(r + h)
c/2pir - r = h
dh/dr = (-c/2pir2) - 1
= (-(2pir(r + h))/2pir2) - 1
= ((- r - h) / r) - 1
= (-2r - h) / r
A = 2pir(r + h)
a) A = 2pir(r + h)
r = c (constant)
A = 2pic(c + h)
A = 2pi(c2 + ch)
A/2pi = c2 + ch
We know that
A = 2pic(c + h)
A = 2pic2 + 2pich
Nope, not right, and it's incorrect from almost the very beginning. What they're looking for is dA/dh, or if you know about partial derivatives, \frac{\partial A}{\partial h}.
tmlrlz said:
b) h = c (constant)
A = 2pir(r + c)
A/2pir = r + c
c = (A/2pir) - r
c) A = c (constant)
c = 2pir(r + h)
c/2pir - r = h
= (-2r - h) / r
b and c are incorrect, as well.
For a, suppose you had A = 2π*6(h + 6). What would dA/dh be? If it was A = 2πk(h + k), with k a constant, what would dA/dh be?
For b, suppose you had A = 2πr(r + 3). What would dA/dr be? If is was A = 2πr(r + k), what would dA/dr be?
A = (2pi * 6)(h+6)
= (12pi)(h + 6)
= 12pih + 72pi
dA/dh = 12pi
A = (2pi * k) (h + k)
= 2pikh + 2pik2
dA/dh = 2pi * k
A = 2pir(r + 3)
= 2pir2 + 6pir
da/dr = 4pir + 6pi
A = 2pir(r+k)
= 2pir2 + 2pirk
dA/dr = 4pir + 2pik
right?
tmlrlz said:
A = (2pi * 6)(h+6)
= (12pi)(h + 6)
= 12pih + 72pi
dA/dh = 12pi
Where in the world did the "6" come from?
= 2pikh + 2pik2
dA/dh = 2pi * k
and now where did "k" come from?
A = 2pir(r + 3)
= 2pir2 + 6pir
da/dr = 4pir + 6pi
where did this "3" come from?
A = 2pir(r+k)
= 2pir2 + 2pirk
dA/dr = 4pir + 2pik
right?
Why not just use the original variables "r" and "h" rather than introducing numbers or other symbols?
but isn't that what i did in my originial answer, the only difference was that i was trying to isolate r or h so that when i got the derivative i could plug their original values back into the derivative to simplify the derivative.
They came from the revised problems that I suggested in post 2.
tmlrlz said:
A = (2pi * 6)(h+6)
= (12pi)(h + 6)
= 12pih + 72pi
dA/dh = 12pi
Right. So in the original problem, with r considered to be constant, you have A = 2πr(h + r), so dA/dh = 2πr.
= 2pikh + 2pik2
dA/dh = 2pi * k
Right.
tmlrlz said:
A = 2pir(r + 3)
= 2pir2 + 6pir
da/dr = 4pir + 6pi
Should be dA/dr, not da/dr, but otherwise OK.
tmlrlz said:
A = 2pir(r+k)
= 2pir2 + 2pirk
dA/dr = 4pir + 2pik
Both fine. Now if A = 2πr(r + h), and h is considered to be a constant, what is dA/dr?
