Difficulty in analyzing automotive tire in workbench
In summary, Chris is trying to model the effects of pressure on the automotive tire, but is having trouble applying material conditions to the model. He has tried using a non-linear solver and split the problem into a lot of substeps, but is still facing the same problem. He has also tried following the error messages that he has obtained, but it seems like the model isn't converging. Chris is going to try applying something much lower for a start and see how it goes.
amanmahajan
Hi,
I am trying to analyze the effects of pressure on the automotive t=ire by modeling and simulating the same in ANSYS workbench. However, I am having trouble applying material conditions to the model.
I wish to use mooney rivlin material but when I apply that based on the guidance given by the following link, my solution does not converge.
video link:
My boundary conditions are fine because if I use a material such as steel, I get a solution.
Kindly help me and let me know where I could go wrong.
The material behaves non linearly and you are using a linear solver.
Chris,
Can you please tell me what changes to make in order to run the analysis.
Thanks
You need to use a non-linear solver (selecting "program controlled" is probably fine too), and you need to split a largely nonlinear problem into a lot of substeps. Depending on the amount of deflection you're seeing, it could be on the order of hundreds of substeps.
Mech_Engineer,
I used program controlled but that failed
So I used substeps as
Initial - 100
Minimum - 10
Maximum - 1000
Using this too the solver ran for a long time but it didn't solve.
I increased the Newton raphson residuals to 4 to see where the force convergence was a problem and it appeared to be along the sidewall.
I increased the no. of elements by refining the mesh but that too has not solved the problem.
Is there anything else that can possibly be wrong with the solution?
Thanks
Following are the error messages that I obtained:
substeps:
initial: 20
minimum: 10
maximum: 100
two more errors continued.
  • What does the force convergence chart look like, was it slowly converging or bouncing all over the place?
  • Are you sure that your model is fully constrained? Does the deflection look something like you're expecting or is it mainly solid body movement?
  • Are you applying a contact condition on the bottom of the tire? What properties are you applying to that boundary?
Mech_Engineer,
The convergence curve begins from below, oscillates about the main line. I do get points in the run where there is convergence but the last two or three points don't converge leading to no solution.
The boundary conditions are alright because if I apply steel as the material to the same model, I get results without any problems.
I am currently analyzing the stresses developed in the tire only due to the inflation pressure. So there are no contact conditions needed to be developed.
Please help.
Thanks for your reply once again!
It sounds to me like the model isn't converging because you don't have enough substeps. You should consider increasing the number of substeps, and applying your pressure gradually through load steps.
Ideally, the force convergence graph should start above the line and converge to below the goal line. If it oscillates about the goal line a lot I'm thinking it means the perturbed system is oscillating; a gradually applied and solved-for load may help with this.
Mech_Engineer
Thank you for your reply. I will try what you suggested and get back to you after that.
Mech_Engineer,
I tried the simulation changes that you had recommended but I am still facing the same problem.
I think you're going to have to try some simplification and see what it takes to get it to converge, either through a simpler geometry and/or simpler material model. Once you're able to get a solution, you can slowly add complexity and see at what point the model is no longer converging. My guess is the pressure load needs to be applied slowly with load steps; how much pressure are you applying? Have you tried a lower pressure to see at what point you can get a solution?
I am applying a pressure of 0.7 Mpa.
No, I have not tried to apply a lower value of pressure on the tire yet to see if that works ok.
I will be doing that now to see if I get some convergence.
Thanks
Try applying something much lower for a start and see how it goes. A pressure of 0.07 MPa might be a good starting point, and could provide you with the structure of load-stepping up from there.
It seems possible your tire is not able to hold 0.7 MPa and is failing to converge because it is structurally failing. A lower starting point might help you visualize this.
That makes sense.
However, the pressure that I applied is the recommended maximum pressure for the tire. But I see what you mean. I'll decrease the load.
When you say you're modeling a tire, do you mean the steel belts and everything? Tires are a pretty complex composite design of rubbers, polymer bands, and layered steel mesh belts; it seems to me they would be a complex analytical challenge.
For now I am just modeling it as a single rubber entity. I have not yet considered the steel reinforcements that go into it.
The "recmmmended maximum pressure" will be for the real tire including the steel reinforcements, not for a rubber ring with no reinforcement.
Exactly what I was getting at. The model isn't converging because just rubber can't hold that much pressure. I'm guessing your modeling efforts will start to converge when you apply less pressure, but the deformations won't really match those of a "real" reinforced tire.
AlephZero & Mech_Engineer,
I didn't think of it.
I found my mistake. When I reduced the pressure significantly to 0.06 psi, The solver was able to converge.
Thanks for all your help. I will go ahead into my analysis now and will post any further problems that I face.
Thanks again.
I am now trying to analyze the same tire by applying contact conditions between the tire and a surface below it. The surface has been modeled as a plate underneath the tire and I have specified frictionless contact.
I try to press the tire against the surface, keeping the inner pressure as 0.05Pa but the results do not converge. Can someone please advise me what could be the error.
Thanks
Aman
Take a close look at all of the things we've talked to you about already, but in addition make sure you using all of the tips I listed here:
Mech_Engineer said:
  1. Pay Close attention to your mesh density in the sheet metal being bent, as well as in the contact conditions that are moving it. The mesh should be of similar size on both sides of the contact, you can use a "contact condition mesh refinement" to make sure this happens.
  2. Make sure you use an "Augmented Lagrange" formulation for the contacts between the sheet metal and press. This formulation will work best with sliding conditions.
  3. As a start, make the contact condition between the sheet metal and press frictionless. Once you get it to converge, then you can think about considering friction.
  4. Make sure your contact condition forces update every substep, and split your problem into MANY substeps (on the order of 100).
  5. Make sure you have accurate material data for your sheet metal, especially into the plastic deformation region which you'll be probing specifically.
  6. Remove the "frictionless supports" which are nonlinear boundary conditions that I suspect will cause you undue grief, and replace them with fixed displacement conditions (0 displacement in axis perpendicular to surface).
That's a good start anyway... I'm not sure of your limitations using ANSYS Academic (the mesh is limited to what, 10K nodes or something?), but hopefully this will start getting you in the ballpark.
https://www.physicsforums.com/showthread.php?t=433240&
Mech_Engineer,
Thanks for your reply.
Here is the problem, The sheet below is simulated as a road surface. If I remove the internal pressure on the tire and displace the sheet upward by 1 mm, the solution converges. This is the case where the sheet is a flexible steel.
However, if I consider the sheet with rigid stiffness behavior in material properties and run the same simulation, the result won't converge.
Additionally, keeping everything the same as the first case, if I apply internal pressure to the tire model and then displace the sheet upward, the solution doesn't converge.
I tried the things you asked me to but I still have the same issues.
Kindly help
Try applying the load steps in reverse- deform the tire first and then apply the internal pressure.
What you are doing is not even close to a realistic analysis of an automobile tire under inflation loading or under contact loading. In a real tire, the tire cords carry most of the load, and the rubber is there just to glue the cord plies together and to prevent the air from escaping from between the cords. Have you looked into the literature on structural analysis of automobile tires, such as Tire Science and Technology. Early analyses of tires used membrane models which accounted for the effects of the tire cords. Later analyses used bending models, and finally, more recent models used detailed finite element. All these took into account the composite nature of the structure.
Hello Mech_Engineer,
I was able to sort out the problem related to the surface and tire contact.
My next step in the analysis is to check the stresses induced in the tire as it rolls on the ground. Can you advise me some steps to get started with that.
My feeling is you're better off making a more realistic model of the tire first, including the belts. Doing all this work to get the model working will have to be done again otherwise.
My advisor first wants me to get a steady state rolling analysis to work and then I will add the reinforcements to the rubber.
That's why I asked for your help to get started on the analysis for rolling.
Thanks
Aman
Hello Mech_engineer,
I have successfully modeled the tire to a close approximation of the real scenario. Can you now please guide me through the process of steps needed to analyze its rolling on a surface to see the stress variation
Thanks
Aman
  • #31
Well it depends on what conditions you want to analyze it under. You need to consider things like angular speed (centripetal acceleration), applied torque, and load it's supporting. You're going to have to decide how you want to approximate ground moving by as well.
Related to Difficulty in analyzing automotive tire in workbench
1. What is the purpose of analyzing automotive tire in workbench?
The purpose of analyzing automotive tire in workbench is to evaluate its performance and durability under various conditions. This allows engineers to make improvements and optimize the design for better safety, efficiency, and cost-effectiveness.
2. What are the common challenges in analyzing automotive tire in workbench?
Some common challenges in analyzing automotive tire in workbench include accurately replicating real-world conditions, obtaining accurate material properties, and dealing with complex contact and friction between the tire and road surface.
3. How is finite element analysis (FEA) used in analyzing automotive tire in workbench?
FEA is a numerical method used to simulate the behavior of a tire under various loads and conditions. It allows engineers to visualize stress and strain distribution, predict failure points, and optimize the design for better performance and durability.
4. What are the important factors to consider when analyzing automotive tire in workbench?
The important factors to consider when analyzing automotive tire in workbench include the tire's material properties, geometric design, loading conditions, and boundary conditions. The tire's contact with the road surface and its interaction with the vehicle's suspension system should also be taken into account.
5. How does analyzing automotive tire in workbench contribute to overall vehicle safety?
Analyzing automotive tire in workbench helps engineers identify potential failure points and make necessary design improvements to ensure the tire can withstand various road conditions and loads. This contributes to overall vehicle safety by reducing the risk of tire failure and improving handling and stability.
  • Mechanical Engineering
10K
9K
