Diffraction by single slit - effect of increasing the slit width
The discussion focuses on the effects of increasing slit width and wavelength on single-slit diffraction patterns. Increasing the slit width (D) results in narrower maxima, while increasing the wavelength (λ) leads to wider maxima. The minima in the diffraction pattern are determined by the formula y = (mλD)/s, where y is the distance from the central maximum to the m-th minimum, m is a positive integer, and s is the single-slit width. This relationship is crucial for understanding the behavior of light in diffraction scenarios.
  • Understanding of single-slit diffraction principles
  • Familiarity with the formula for minima in diffraction patterns
  • Basic knowledge of wave properties, specifically wavelength
  • Concept of maxima and minima in interference patterns
  • Study the mathematical derivation of the single-slit diffraction formula
  • Explore the impact of slit width on diffraction patterns using simulation tools
  • Investigate the relationship between wavelength and diffraction in various media
  • Learn about multi-slit interference and its comparison to single-slit diffraction
Physics students, educators, and anyone interested in wave optics and the principles of diffraction.
physicsilliterate
For diffraction by a single slit, what is the effect of increasing (a) the slit width, and (b) the wavelength? It was a problem on my daughter's final and I never seemed to be able to answer it for her. :confused:
The answer lies in the fact that the minima are located at intervals of n\lambda / D (value of sin)... so a bigger slit (D) makes narower maxima and a larger wavelength (\lambda) makes wider maxima.
for single-slit diffraction, the condition for MINIMUMs is:
y \ = \ \frac{m \lambda D}{s}
where y is the distance from central max to the m-th minimum of the diffraction pattern, m a positive integer, λ the wavelength, D the distance between single-slit and distant observation screen where diffraction pattern will be observed, and s the single-slit width. Thus:
a) increasing single-slit width will decrease width of central max ("shrink the diffraction pattern");
b) increasing wavelength will increase width of central max ("expand the diffraction pattern")
  • · Replies 34 ·
