Dificulty with Einstein's derivation of TAO
  • Thread starter Thread starter disknoir
    Derivation
disknoir
Hi,
I'm trying to work my way through Einstein's 1905 paper On the electrodynamics of moving bodies.
I'm having problems with section § 3. I follow until he says
"If we place x'=x-vt, it is clear that a point at rest in the system k must have a system of values x', y, z, independent of time."
I understand this as follows:
Because the point is at rest in system k it's position is independent of time as measured by an observer also at rest in system k. However, the position of this point would not be independent of time when measured by an observer at rest in system K.
Why use x' instead of \xi? Is he using a third refernce frame?
I'm confused here. I've searched for explanations of this and in the few I have found the author doesn't seem to understand it either.
Here was my attempt to follow Einstein's 1905 derivation and explain conceptually what was going on with some of the steps:
First Einstein assumes you have to coordinate systems defined by
measurements on a system of rigid measuring rods and clocks, K and k,
with all the spatial axes parallel and with k moving at velocity v along
K's x-axis. K's coordinates are (x,y,z,t) while k's coordinates are (xi,
eta, zeta, tau). Then he defines a new coordinate x'=x-vt, and says "it
values x', y, z, independent of time". Although he doesn't state it this
way, what he has effectively done is to introduce a *third* coordinate
system Kg, with y,z,t coordinates identical to K, but with x' coordinate
given by x-vt. To make this a little clearer, I'm going to modify his
notation and say that coordinate system Kg uses coordinates x',y',z',t',
with these coordinates related to K's coordinates x,y,z,t by a Galilei
transform:
x'=x-vt
y'=y
z'=z
t'=t
An important thing to notice is that, unlike k and K, Kg doesn't
necessarily correspond to the measurements of any observer using a
system of measuring-rods and clocks; it isn't really an inertial
reference frame at all. So, the postulate that all observers must
measure the speed of light to be c in their own rest frame doesn't apply
to Kg. In fact, since we know light must travel at c in both directions
in K, and Kg is related to K by a Galilei transform, it must be true
that light travels at (c-v) in the +x' direction of Kg, and (c-v) in the
-x' direction of Kg.
So now a light beam is sent from the origin of k at tau0, reflected by a
mirror at rest in k at tau1, and returned to the origin at tau2. As
Einstein said, any point which is at rest in k must also be at rest in
this new coordinate system which I am calling Kg, so neither the point
of origin nor the mirror are moving in Kg. So if the origin of Kg
coincides with the origin of k, and if we say the mirror is at position
x'=xm' in Kg, then since light travels at (c-v) in the +x' direction of
Kg, the light will take time xm'/(c-v) to reach the mirror in Kg, and
since light travels at (c+v) in the -x' direction of Kg, it will take an
additional time of xm'/(c+v) to return to the origin. Thus, if the light
is emitted at t'=t0' in Kg's frame, it is reflected at t'=t0' +
xm'/(c-v), and returns to the origin at t'=t0' + xm'/(c-v) + xm'/(c+v)
So, if k's coordinate tau is expressed as a function of Kg's coordinates
like tau(x',y',z',t') then we have:
tau0 = tau(0, 0, 0, t0')
tau1 = tau(xm', 0, 0, t0' + xm'/(c-v))
tau2 = tau(0, 0, 0, t0' + xm'/(c-v) + xm'/(c+v))
Now, since k represents the actual measurements of a non-accelerating
observer using his measuring-rods and clocks, we know that light must
travel at c in both directions in this coordinate system, and since the
origin and the mirror are at rest in k, the light must take the same
amount of time to reach the mirror as it takes to be reflected back to
the origin in k. So, this gives 1/2(tau0 + tau2) = tau1, which
substituting in the expressions above gives
1/2[tau(0, 0, 0, t0') + tau(0, 0, 0, t0' + xm'/(c-v) + xm'/(c+v))] =
Then he goes from this to the equation 1/2(1/(c-v) + 1/(c+v))*(dtau/dt')
= dtau/dx' + (1/c-v)*(dtau/dt'), which also confused me for a little
while because I didn't know what calculus rule he was using to go from
the last equation to this one. But then I realized that if you just
ignore the y' and z' coordinates and look at tau(x',t'), then since he
says "if x' is chosen infinitesimally small", you can just assume tau is
a slanted plane in the 3D space with x',t' as the horizontal axes and
tau as the vertical axes. The general equation for a slanted plane in
these coordinates which goes through some point xp', tp', and taup would be:
tau(x',t') = Sx'*(x' - xp') + St'*(t' - tp') + taup
Where Sx' is the slope of the plane along the x' axis and St' is the
slope of the plane along the t' axis. If we say this plane must go
through the three points tau0, tau1 and tau2 earlier, then we can use
tau0's coordinates for xp', tp' and taup, giving:
tau(x',t') = Sx'*x' + St'*t' + tau0
So, plugging in tau1 = tau(xm', t0' + xm'/(c-v)) gives
tau1 = Sx'*xm' + St'*(t0' + xm'/(c-v)) + tau0
And plugging in tau2 = tau(0, t0' + xm'/(c-v) + xm'/(c+v)) gives:
tau2 = St'*(t0' + xm'/(c-v) + xm'/(c+v)) + tau0
So plugging these into 1/2(tau0 + tau2) = tau1 gives:
1/2(tau0 + St'*(t0' + xm'/(c-v) + xm'/(c+v)) + tau0 ) = Sx'*xm' +
With a little algebra, this reduces to:
(1/2)*St'*(1/(c-v) + 1/(c+v)) = Sx' + St'*(1/(c-v))
And since tau(x',t') is just a plane, of course St' = dtau/dt' and Sx' =
dtau/dx', so this gives the equation 1/2(1/(c-v) + 1/(c+v))*(dtau/dt') =
dtau/dx' + (1/c-v)*(dtau/dt') which Einstein got.
He then reduces this to dtau/dx' + dtau/dt'*(v/(c^2 - v^2)) = 0, which
is just algebra. He also says that light moves along the y'-axis and
z'-axis of Kg at velocity squareroot(c^2 - v^2), which isn't too hard to
see--a light beam moving vertically along the zeta-axis of k will also
be moving vertically along the z'-axis of Kg since these coordinate
systems aren't moving wrt one another, but in K the light beam must be
moving diagonally since k is moving at v in k, so if you look at a
triangle with ct as the hypotenuse and vt as the horizontal side, the
vertical side must have length t*squareroot(c^2 - v^2), and since z'=z
and t'=t the light beam must also travel that distance in time t' in
Kg's coordinate system. The same kind of argument shows the velocity is
also squareroot(c^2 - v^2) in the y'-direction.
Since tau(x',y',z',t') is a linear function (ie tau(x',y',z',t') = Ax' +
By' + Cz' + Dt'), then from this you can conclude that if dtau/dx' +
dtau/dt'*(v/(c^2 - v^2)) = 0 for a light ray moving along the x'-axis,
tau(x',t') must have the form tau = a(t' - vx'/(c^2 - v^2)) where a is
some function of v (so that dtau/dt' = a and dtau/dx' = -av/(c^2 - v^2),
which means dtau/dx' = (-v/(c^2 - v^2))*dtau/dt').
Next he says that in the k coordinate system the light ray's position as
a function of time would just be xi(tau)=c*tau, so plugging that
expression for tau in gives xi=ac(t' - vx'/(c^2 - v^2)). But in system
Kg, this light ray is moving at velocity (c-v), so its t' coordinate as
a function of x' is t'(x') = x'/(c-v). Plugging this in gives xi =
ac(x'/(c-v) - vx'/(c^2 - v^2)) = a*(c^2/(c^2 - v^2))*x'.
Similarly, if light is going in the eta-direction then eta(tau)=c*tau,
so plugging in tau = a(t' - vx'/(c^2 - v^2)) gives eta=ac(t' - vx'/(c^2
- v^2)). In Kg this ray is moving at squareroot(c^2 - v^2) in the
y'-direction, so t'(y')=y'/squareroot(c^2 - v^2), and plugging this in
gives eta= a(y'/squareroot(c^2 - v^2) - vx'/(c^2 - v^2))...since x'=0
for this ray, this reduces to eta=(ac/squareroot(c^2 - v^2))* y'. The
relation between zeta and z' is exactly the same, so we have:
xi = a*(c^2/(c^2 - v^2))*x'
eta = (ac/squareroot(c^2 - v^2))* y'
zeta=(ac/squareroot(c^2 - v^2))* z'
Since the relation between Kg coordinates (x',y',z',t') and K
coordinates (x,y,z,t) is just x'=x-vt, y'=y, z'=z, t'=t, we can plug in
and simplify to get:
tau = Phi(v) * Beta * (t - vx/c^2)
xi = Phi(v) * Beta * (x - vt)
eta = Phi(v) * y
zeta = Phi(v) * z
Where where Beta = c/squareroot(c^2 - v^2) = 1/squareroot(1 - v^2/c^2),
and Phi(v) = ac/squareroot(c^2 - v^2) (since a was an undetermined
function of v in the first place he just writes Phi(v)).
To find Phi(v), he then imagines a coordinate system K' which is moving
at -v relative to k (and unlike Kg, this coordinate system is supposed
to correspond to the measurements made on a system of measuring-rods and
clocks, so it's a valid inertial reference frame). *He uses
(x',y',z',t') for the K' coordinate system, but since I've already used
that for Kg, let's call the K'-coordinates (x",y",z",t"). Then the
transform from k-coordinates to K'-coordinates would have to be:
t" = Phi(-v) * Beta(-v) * (tau + v*xi/c^2) = Phi(v)*Phi(-v)*t
x" = Phi(-v) * Beta(-v) * (xi + v*tau) = Phi(v)*Phi(-v)*x
y" = Phi(-v) * eta = Phi(v)*Phi(-v)*y
z" = Phi(-v) * zeta = Phi(v)*Phi(-v)*z
If K' is moving at -v in the k-system, and k is moving at +v in the
K-system, then K and K' should really be the same system, so
Phi(v)*Phi(-v) should be 1. Then he argues that if you have a rod of
lenght l lying along the eta-axis of k and at rest in that system, then
if you transform the coordinates of its ends into the K-system, you find
that its length in the K-system is l/Phi(v), and by symmetry he argues
that the length of a vertical rod moving horizontally can only depend on
the magnitude of the velocity and not the direction, so l/Phi(v) =
l/Phi(-v), which means Phi(v) = Phi(-v)...combining with Phi(v)*Phi(-v)
= 1 which he obtained earlier, he concludes that Phi(v)=1, which gives
him the Lorentz transform.
Also, in the paragraph above that starts "Then he goes from this to the equation 1/2(1/(c-v) + 1/(c+v))*(dtau/dt') = dtau/dx' + (1/c-v)*(dtau/dt'), which also confused me for a little while because I didn't know what calculus rule he was using to go from the last equation to this one", I used an argument about what a smooth function looks like when you zoom in on an infinitesimal region, but in that step you can also just use the chain rule for partial derivatives, as explained in post #6 of this thread.
I started reading a National Geographic article related to the Big Bang. It starts these statements: Gazing up at the stars at night, it’s easy to imagine that space goes on forever. But cosmologists know that the universe actually has limits. First, their best models indicate that space and time had a beginning, a subatomic point called a singularity. This point of intense heat and density rapidly ballooned outward. My first reaction was that this is a layman's approximation to...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
