Why do some papers use binomial expansion in dimensional regularization?
  • Thread starter Thread starter RedX
    Regularization
RedX
I was looking at a paper that used dimensional regularization and the following expression was derived:
\int dx \mbox{ }[p^2(1-x)^2-\lambda^2(1-x)]^{\epsilon}
Factoring out p^2(1-x)^2:
\int dx \mbox{ }[p^2(1-x)^2]^{\epsilon}[1-\frac{\lambda^2}{p^2(1-x)}]^{\epsilon}
The part that I don't understand is that they expanded the rightmost factor in binomial expansion. \lambda^2 is smaller than p^2 (in fact \lambda^2=p^2-m^2), but the 1/(1-x) changes all that when x approaches 1, making \frac{\lambda^2}{p^2(1-x)} much greater than 1.
Is it okay to expand the rightmost factor in binomial expansion because when x goes to 1, the factor on the left [p^2(1-x)^2]^{\epsilon} goes to zero, so it doesn't matter what's on the rightmost side at that point? If so, isn't there an error term that needs to be calculated?
Could be. Could you give us some more context? Do you have the citation for the paper? Cheers,
Adam
Adam
There's a lot of pages, so I'll just link to a link of it:
http://www.slac.stanford.edu/spires/find/hep/www?rawcmd=FIND+A+DONOGHUE+AND+HOLSTEIN+and+robinett&FORMAT=www&SEQUENCE=
It's the second paper in the list, and you can download a copy by clicking on Scanned Version (KEK).
The part I'm referring to is on page 49, equation (A1).
It's an older paper, so they probably do things a little differently, but still, the result should be the same as with today's techniques, so I'm quite surprised: I haven't seen any of these techniques tried before in QFT books on QED.
*actually, it's page 50 if you click on the scanned images (Tiff and Gif). On the actual paper, it is page 49.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
