Dimensioning a house's main-pipe
  • Thread starter Thread starter TSN79
When dimensioning a house's main water pipe, it is essential to consider both hot and cold water capacities, as fixtures may not operate simultaneously. Each fixture is rated in 'fixture units,' which helps determine the appropriate pipe size based on expected usage. The main pipe typically does not exceed 3/4 inch ID, as not all fixtures will be in use at the same time, similar to electrical service calculations. For accurate sizing, reference plumbing codes like the BOCA plumbing code, which provide guidelines for calculating diversified loads. Overall, understanding the balance of hot and cold water usage is crucial for proper pipe dimensioning.
TSN79
When dimensioning pipes for tap-water I add up the capacity of each water-point. My question is, should I also add the capacity for hot water? Let's say that I have 10 fossets, each of which can deliver 0,2 l/s of either hot or cold water or a combination. When determining the size of the house's main pipe, should I then only be concerned about the amount of cold water, since a fosses can't deliver 0,2 l/s of both hot and cold water at the same time?
Go buy yourself a book on plumbing. They have guidlines in there that make it much easier. They size different things in I believe what is called 'fixture units'. Each sink, shower, toilet, etc. will be rated at a certain fixture unit. It takes a certain size pipe to carry the water for a given number of fixture units. It is very seldom the main pipe in a residence is bigger than 3/4 inch ID. Also, consider than not all fixtures will be used at the same time. The same logic applies in electrical services. Add the current from each individual breaker in a breaker panel and you will find it exceeds the current of the main breaker. Not everything is used all at once.
The book you probably want is the BOCA plumbing code. It gives guidelines for that. You don't, for example, just add up all your usage points because they won't all be on at the same time.
However, to size the incoming service, you do need to consider both the hot and cold water usage because the diversified numbers will be lower than the actual capacities. Ie. [made-up numbers] if you have 10 fixtures at .2 l/s, you may have a diversified load of .5 l/s each for hot and cold water for a total of 1 l/s for the incoming service.
...and everything Averagesupernova said is correct.
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
