Calculating Diopters for Bifocals: What Power Should They Have?
  • Thread starter Thread starter DrMcDreamy
    Calculation
The discussion centers on calculating the appropriate diopter power for bifocals based on a person's vision needs. For distant vision, the upper portion of the bifocals should accommodate a range from 49 cm to 1.5 m, leading to a calculated power of approximately 2.04 D or 0.67 D, indicating confusion in the calculations. The lower portion, designed for comfortable viewing at 25 cm, requires a power of 4 D. The original poster expresses uncertainty about their calculations and seeks clarification. Accurate diopter calculations are essential for effective bifocal prescriptions.
DrMcDreamy
This is a 2 part problem:
4- A person is to be fitted with bifocals. She can see clearly when the object is between 49 cm and 1.5 m from the eye. The upper portions of the bifocals should be designed to enable her to see distant objects clearly. What power should they have? Answer in units of diopters.
5- The lower portions of the bifocals should en- able her to see objects comfortably at 25 cm. What power should they have? Answer in units of diopters.
P=\frac{1}{f}
4- P = \frac{1}{0.49 m} = 2.04 x 100 = 204 D
or it might be P = \frac{1}{1.5 m} = 0.666 x 100 = 66.6 D
5- P = \frac{1}{0.25 m} = 4 x 100 = 400 D
I know I am doing something wrong can you help me?! TIA
*bump*
*bump*
