Neutral Wire Current Direction and Magnitude in AC Power Distribution
The direction of current flow through the neutral wire in AC power distribution is determined by the alternating nature of the current, which flows one way during one half of the cycle and reverses during the other half. The magnitude of the current in the neutral wire is calculated using Ohm's Law, where it is proportional to the voltage divided by the impedance of the load. When the active and neutral conductors run parallel, their currents are equal and opposite, resulting in the cancellation of magnetic fields outside the wires but not in the space between them.
  • Understanding of AC power distribution systems
  • Familiarity with Ohm's Law
  • Knowledge of electrical impedance
  • Concept of magnetic fields in electrical circuits
  • Research the principles of AC power distribution
  • Study the application of Ohm's Law in electrical circuits
  • Explore the effects of impedance on current flow
  • Investigate the behavior of magnetic fields around conductors
Electrical engineers, technicians working with AC power systems, and students studying electrical engineering concepts will benefit from this discussion.
cnunez12
What determines the direction of current flow through the neutral wire? What determines the value of the current through the neutral wire?
Assuming the subject is AC power distribution. The neutral conductor carries the same current as the active conductor. The current flows first one way around the return circuit, then reverses and flows back again, it repeats that every cycle.
The magnitude of the current is proportional to the voltage divided by the impedance of the load. That is Ohm's Law.
Where the two conductors run parallel, the active and neutral currents are equal and opposite. That means the magnetic fields cancel outside the region of the wires, but not in the small region between them.
Both the main electrical cable (three-phase, line to neutral=230V, line to line =400V, 50Hz) and the water supply line(ppr pipe) are underground, below the earth in the garden, located next to each other, the main electrical power has damaged insulation, bare live line is exposed to a water leak from a broken main potable water line. So fault contact happen before RCD. Could this situation be dangerous, especially if a person is showering at the same time? I am trying to understand whether...
  • · Replies 29 ·
  • · Replies 26 ·
11K
