Directional covariant derivative
snoopies622
Is this correct?
<br /> <br /> \nabla _{\vec{p}} \vec{p} = (\nabla_a \vec{p} ) p^a<br /> <br /> =&lt; (\nabla_a p^0 ) p^a, (\nabla_a p^1 ) p^a , (\nabla_a p^2 ) p^a, (\nabla_a p^3 ) p^a &gt;<br /> <br />
(where the a's are summed from 0 to 3)
Hi again, atyy. Perhaps I should re-formulate; I think this is right but I was hoping for confirmation:
The covariant derivative of a type (a,b) tensor is a type (a,b+1) tensor, but the directional covariant derivative is still type (a,b), since one takes the inner product of the covariant derivative and the directional vector, thereby losing the extra lower rank.
I was wondering about this because somewhere in Schutz's First Course he writes the geodesic equation simply as \nabla _{\vec{p}} \vec{p} = 0, and I wasn't certain what \nabla _{\vec{p}} \vec{p} meant.
I think it's something like this.
Expand u in basis vectors (linearity):
<br /> \nabla _{\bold{u}} \bold{v} <br /> = \nabla _{{u^i}\bold{e_i}} \bold{v} <br /> ={u^i} \nabla _{i} \bold{v}<br />
Expand v in basis vectors (product rule or Leibniz property):
<br /> {u^i} \nabla _{i} \bold{v}<br /> ={u^i} \nabla _{i} v^j\bold{e_j}<br /> ={u^i} (v^j\nabla _{i} \bold{e_j}+\bold{e_j}\nabla _{i} v^j})<br />
Use definition of Christoffel symbols and covariant derivative of a scalar field:
<br /> \begin{equation*}<br /> \begin{split}<br /> \{}{u^i} (v^j\nabla _{i} \bold{e_j}+\bold{e_j}\nabla _{i} v^j}) \\<br /> &amp;={u^i} (v^j\Gamma^{k}_{ij} \bold{e_k}+\bold{e_j}{\frac {\partial v^j}{\partial x_i}}) \\<br /> &amp;=({u^i}v^j\Gamma^{k}_{ij} \bold{e_k}+{u^i}\bold{e_j}{\frac {\partial v^j}{\partial x_i}}) \\<br /> &amp;=({u^i}v^j\Gamma^{k}_{ij} \bold{e_k}+{u^i}\bold{e_k}{\frac {\partial v^k}{\partial x_i}}) \\<br /> &amp;=({u^i}v^j\Gamma^{k}_{ij} \bold+{u^i}{\frac {\partial v^k}{\partial x_i}}){\bold{e_k}}<br /> \end{equation*}<br /> \end{split}<br />
For Schutz's equation, let the unknown coordinates of the curve be x_i=x_i(\tau).
Set u^i=v^i=({\frac {dx(\tau)}{d\tau}})^i={\frac {dx{_i}(\tau)}{d\tau}} as the tangent vector along the curve.
For a geodesic, set the covariant derivative of the tangent vector along the curve to zero (ie. no acceleration):
{\frac {dx{_i}}{d\tau}}{\frac {dx{_j}}{d\tau}}\Gamma^{k}_{ij} \bold+{\frac {dx{_i}}{d\tau}}({\frac {d^2x{_k}}{d\tau^2}}{\frac {d\tau}{dx{_i}}})}={\frac {dx{_i}}{d\tau}}{\frac {dx{_j}}{d\tau}}\Gamma^{k}_{ij} \bold+{\frac {d^2x{_k}}{d\tau^2}}}=0
We can also get the same differential equation by requiring the integrated proper time along the curve to be extremal. A given metric fixes the Christoffel symbols. Solving the differential equation will give you the coordinates of a geodesic x_i=x_i(\tau).
Need a day to process...
Thanks, atyy; I follow now. And it turns out that the relationship I was looking for is right here in Schutz's section 6.4, "Parallel-transport, geodesics and curvature":
<br /> <br /> \nabla _ {\vec U} \vec U = 0 \Rightarrow "in component notation" U^{\beta} U^{\alpha} _{;\beta}=...=0
I guess in general it pays to read page 166 before page 186.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
