Directional derivative question
The discussion revolves around the concepts of directional derivatives and level curves in the context of multivariable calculus. Participants are exploring the definitions and implications of these concepts as they relate to a specific problem.
  • Participants express confusion regarding the meaning of 'level curve' and how it relates to 3D graphs and contour maps. There are questions about the interpretation of the directional derivative, particularly in relation to the gradient and its direction.
Some participants have provided clarifications about level curves and the directional derivative, suggesting a more visual understanding through contour maps. Others indicate a need for further explanation of foundational concepts to fully grasp the problem.
There is an emphasis on the forum's rules regarding showing work, which may influence the depth of understanding among participants. Some express a struggle with foundational concepts, which affects their ability to articulate their reasoning clearly.
question dude
I've done the first part, but I'm stuck on the second paragraph of the question. Maybe I'm being stupid, I don't even understand exactly what is meant by, 'the level curve'.
I also don't quite understand the whole concept of directional derivative. When it says, 'the gradient in the direction making an angle A with the x-axis, how should I think of this? what does the gradient mean in this context?
because when its just a simple curve/line on an xy axis, I know what the 'gradient' means, it is literally how much 'y' changes per unit x along that curve/line. But when I'm told about a 'gradient in a direction', I'm confused.
hey, question dude! :smile:
question dude said:
… what is meant by, 'the level curve'.
think of the 3D graph, z = f(x,y)
you can make a 2D contour map showing the lines of equal height
those contours are the level curves :wink:
the directional derivative in the direction (cosθ,sinθ) is df(kcosθ,ksinθ)/dk
it's the rate at which f increases if you go along the line y/x = tanθ :smile:
You are supposed to show your work, confused or not (those are PF rules). I don't see how you can have done the first part (which involves directional derivatives) but then claim you do not understand directional derivatives. I would need to see your work in order to grasp what is going on.
Thanks a lot! I understand what's going on now. Before I was just plugging in the numbers without knowing the concepts properly.
Sorry about that, what I meant to get across, was that I understood the method in a sort of algorithmic way, but didn't understood the reason behind steps due to not understanding some basic stuff like 'level curve'. Anyway its sorted now.
