Directly measure frequency of light source
A method to directly measure the frequency of a light source involves using devices like diffraction gratings or interferometers. Coherent detection techniques, such as fast reference oscillators and heterodyne detectors, can measure electromagnetic light frequencies up to the GHz range, with potential extensions into the THz regime. Heterodyne measurements of visible light can also be performed using optical frequency standards or frequency combs. However, light sources typically emit a mixture of frequencies, which can be analyzed with a spectrometer. There is currently no known handheld device that provides an immediate spectrum output from a light source.
JoMo
Can anyone tell me if there's a device or method to DIRECTLY mesaure the frequency of a light source?
Thanks,
Joe M.
Science news on Phys.org
I am not sure what you meant by "DIRECTLY" measure the frequency. One way would be to use a diffraction grating and using a collimated beam of the light. In fact you can use other interferometers for this purpose too.
Thanks
-SNB
If by 'directly', you mean coherent detection (instantaneous amplitude and phase), then direct measurements are possible using fast reference oscillators and heterodyne detectors for EM light up to the GHz range or so (millimeter waves). That may have been extended to the THz regime recently, but I have no reference for that.
It's possible to perform heterodyne measurements of visible light using an optical frequency standard as well, and I suppose the recent generation of an optical frequency comb could be used as an alternative, but it's not clear by your question what you mean by 'direct' measurement (i.e. counting cycles?)
Light sources never have a single frequency, they are always a mixture of different frequencies, which can be analyzed by a spectrometer for example.
Do you perhaps mean by 'direct measuring' that you take some hand-held device, point it at a light source and it spits out the light's spectrum? I don't know of any device that does this but I can't see why it shouldn't exist.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
