Disadvatage of PIV measurment system
  • Thread starter Thread starter transformer
    Measurment System
The Particle Image Velocimetry (PIV) system has notable disadvantages, including the requirement for a powerful and costly laser to create a laser sheet. Additionally, specialized image tracking software is necessary for data analysis, adding to the overall expense. PIV is not suitable for all flow types, as it struggles with certain conditions, such as supersonic flows. These limitations can hinder its applicability in various experimental setups. Overall, while PIV is a valuable measurement technique, its costs and specific flow restrictions can be significant drawbacks.
transformer
I'm trying to find out some information on the piv system and how it compares to other systems of measurement. Essentially I want to know if anyone knws any disadvantages of the piv (Particle image velocimetry) system.
Thanks
Transformer
Well for one you will need a laser sheet which usually requires a pretty powerful laser = very expensive. You also need specialized image tracking software.
Second is that not all flows allow this technique. I have never heard of supersonic PIV for instance.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
