Discharge of a Pressure Vessel Containing Liquid Nitrous Oxide
The discussion revolves around modeling the mass flow rate of liquid nitrous oxide discharging from a closed tank through an orifice. Participants explore the dynamics of liquid discharge, pressure changes, and phase behavior, while considering various assumptions and conditions related to the system's design and operation.
  • One participant seeks to model the mass flow rate of liquid nitrous oxide as it discharges from a tank, questioning the applicability of traditional gas discharge equations to a liquid scenario.
  • Another participant mentions prior experience with similar tank designs and stresses the importance of modeling mass flow rate due to observed discrepancies in discharge times.
  • Concerns about flammability and safety considerations related to nitrous oxide are raised, with one participant noting that nitrous oxide is not flammable at room temperature.
  • Participants discuss the phase behavior of nitrous oxide near the exit orifice, with some suggesting that vaporization occurs as the liquid approaches the orifice.
  • One participant proposes temporarily neglecting gravity to simplify the analysis, while another questions the implications of this assumption on the flow dynamics.
  • There is a discussion about the equilibrium vapor pressure of nitrous oxide at specific temperatures and how it affects the discharge process.
  • One participant challenges the feasibility of maintaining a pressure of 50 bar in the tank if the headspace is filled with gaseous nitrous oxide, suggesting the need for a pressurized gas to achieve such conditions.
  • Another participant provides a Bernoulli equation to describe the pressure dynamics at play when the valve is opened, indicating a transition from liquid to vapor phase as pressure drops.
Participants express multiple competing views regarding the behavior of nitrous oxide during discharge, the effects of gravity, and the assumptions about pressure and phase transitions. The discussion remains unresolved with no consensus on the best modeling approach or the implications of various assumptions.
Participants note limitations related to assumptions about compressibility, the adiabatic nature of the system, and the impact of gravity on flow dynamics. The discussion also highlights the need for clarity on the initial conditions and the state of the fluid in the tank.
Alexander Fernandes
I want to design a closed tank with an orifice hole (that can be opened and closed remotely) at the bottom of the tank and model how the mass flow rate of liquid nitrous oxide changes with respect to time, as the liquid nitrous oxide leaves the tank due to a pressure difference across the orifice. I want to also try and stay away from using CFD software as complete accuracy is not really overly important here. I have seen a lot of problems online where they solve discharge problems but all seem to use pressurised gases and the Ideal Gas Law. My problem, however, involves a pressurised liquid or am I missing something.
Known Data:
Initial Tank Pressure (assumed Uniform)
Initial Tank Temperature (assumed Uniform)
External Pressure (let's assume atmospheric)
Orifice Diameter / Area
Tank Diameter / Area
Fluid Density
Tank length
Coefficient of Discharge
dm/dt = cd * Ao * rho * sqrt(2 * ((P(t)-Pa)/rho) - gh(t))
where:
dm/dt = mass flow rate
cd = coefficient of discharge
Ao = orifice cross-sectional area
rho = fluid density
P(t) = tank pressure as a function of time
Pa = atmospheric pressure
g = acceleration due to gravity
h(t) = head of fluid as a function of time
I have tried using Bernoulli's equation, shortly after realising that the problem might be unsteady-flow and that the fluid might have to be considered compressible making the aforementioned formula useless. I also used the formula above which I derived from Bernoulli's equation assuming Quasi-steady flow but I'm not sure that is correct either.
Thread closed temporarily for Moderation...
Thread re-opened for now.
Can you comment about any flammability issues with this setup? Are you familiar with Intrinsic Safety and Explosion Proof considerations? Thanks.
Well Actually I have already designed a similar tank and calculated the longitudinal stress and hoop stress that the nitrous oxide might impart on the vessel in question. I also carried out FEA on the tank to back up hand any calculations. All stresses are well below the youngs modulus of the tanks material (Aluminium Alloy 6061T6). I used a similar tank with the hybrid rocket motor I designed as part of my FYP(Final year project), however the discharge time of the tank was a lot longer than predicted due to decrease in pressure over the course of the discharge period. Hence, why I would like a model of the mass flow rate. As for flamability, nitrous oxide is not flammable at room temperature (nor at its cryogenic temperature). Nitrous oxide needs to heated to the point at which it breaks it nitrogen-oxygen bonds (577 degrees c) before any combustion could take place.
Mechanistically, what would you assess the flow and phase behavior to be within a few orifice diameters of the exit orifice? What would be the state of the N2O right at the exit orifice? What do you think the streamlines in the region would look like?
The N20 would be in the gaseous phase and will want to expand at the exit plane of the orifice.
Please dope this out in more detail. What is happening as the N2O approaches the exit orifice?
Also, is the tank sealed at the top? Is there N2O vapor above the liquid, with no air in the head space? What is the fraction of liquid and vapor in the tank to start?
There is a relief valve at the top of the tank, so at the start the tank can be considered to be comprised of 100% liquid nitrous oxide pressurised at 50 bar with a temperature of 180K. A valve at the bottom of the tank with a diameter (Do) is opened. The exit plane of the orifice can be considered to have 1 bar of pressure and a temperature of 298K (initially). My guess it that the liquid starts to vapourise at the entrance of the orifice (is that correct). Ultimately I just want to model the pressure drop in the tank, mass flow rate and the time needed for the system to reach equilibrium.
Gravity is a complicating factor, because there will be vapor formed close to the exit orifice, and the vapor will tend to rise. Would you be willing to temporarily assume that there is no gravity, and solve it that way first? What is the equilibrium vapor pressure of N2O at 180 K? (Antoine equation parameters are available on the NIST data sheet). Is the temperature going to somehow stay at 180 K, or does this have to be adiabatic?
Without gravity, I would envision a spherically converging flow toward the exit. At some radial distance from the exit, there would be a phase transition from liquid to vapor. The phase transition would occur at the equilibrium vapor pressure.
That's my thinking so far.
The vapour pressure for nitrous oxide at 180K is around 0.6152 bar. I don't mind the assumption that the system is adiabatic but I think the system should not be isothermal as the tank will cool as the vapoursied fluid leaves the tank. As for gravity I am not sure. I only really care about solving this problem as a one dimensional problem, so the stream line can be considered going straight in the axial direction of the orifice.(accuracy is not overally important here otherwise I would have just used CFD).
So, if the pressure is 0.6 bars, what would cause the liquid to come out of the tank?
This graph was taken from the NIST webbook and shows a vapour pressure of 0.6 bar at 180K, ok so maybe the liquid does not vapourise in the tank but the liquid must come out because you have a pressure difference of 49 bar across the orifice.
What is it pressurized with? You'd need some sort of pressurized gas in the headspace to achieve this - if the headspace is just gaseous nitrous oxide, it can't maintain 50 bar at 180K, since it'll just condense onto the liquid surface until it is at the vapor pressure of 0.6 bar. If you're talking about a hybrid rocket tank, you generally wouldn't refrigerate it for this reason - you'd rather have the nitrous at 315K or so to allow it to self-pressurize the volume above the liquid.
OK. Here's how this plays out, including gravity. When you first open the valve on the bottom, a small amount of liquid will leak out until the N2O has decompressed to the point where the pressure at the top of the liquid has dropped to 0.65 bar. From that point on, a vapor phase will form above the liquid, and the liquid pressure will rise with depth. The Bernoulli equation for this situation will be
$$65000+\rho g h+0=100000+0+\frac{1}{2}\rho v^2$$where the left side of this equation applies to the top liquid surface, the right hand side of the equation applies to the exit orifice, ##\rho## is the fluid density, h is the liquid level in the tank, and v is the liquid velocity coming out of the exit orifice.
Ok got it, thanks.
  • · Replies 45 ·
  • · Replies 20 ·
12K
